Disk brakes conversion possible?
Results 1 to 18 of 18
    Feb 2018
    I have basic frame old school beach cruiser i want to install disk brakes in the front only.
    1. How to mount rotor my wheel hub is basic no thread or mounting holes it. Do i need to purchase new wheel or there's some adapter?
    I found this thing it threads on the hub, am i supposed to use rear hub in the front to bolt it on?
    2. Fork has no mounts for calipers i think this $6 adapter should work?
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    You will need a new hub.
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    "Can you do it?"
    Yes.
    "Is it (really) a good idea?"
    No.
    Feb 2005
    Rear hubs are between 130-135mm wide (typically) whereas front hubs are 100mm wide, so you would also need to fiddle with that.
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    Can I ask why you want to do this? What advantages do you expect to achieve?
    Oct 2013
    It'll look cool?
    BANNED
    Feb 2002
    Catch a ride to the top of the mountain with your beach cruiser and coast down?
    I love to climb!
    Reputation: Jwiffle's Avatar
    Mar 2005
    Quote Originally Posted by PimpMan View Post
    You won't be able to use a rear hub in the front, as the spacing is too different. You would need to buy a new front wheel with a disc hub.
    The fork of the bike is not designed to handle a disc brake, so although that adapter may "work,"* I would definitely not recommend it. Beach cruisers generally aren't used in such a manner as to necessitate disc brakes. If you are using one in a manner that does, I would argue that you are using the wrong bike for the job and should look into a new bike.
    *I can only really see it working with a bolt on hub, and you'll probably need a longer axle, as it looks like that adapter needs to also have the axle sit in it along with the fork dropout.
    Edit: actually may not need a longer axle, just different size spacers to get the spacing right, since the adapter sits inside the frame/ fork.
    Stop in at Element Sports. www.elementsport.com
    Get Out! Have Fun!
    Russian Troll Farmer
    Sep 2016
    Somehow, I think this post was a "troll".
    "L'enfer, c'est les autres"
    [REDACTED]
    May 2014
    With a name like PimpMan, how could you tell?
    Sep 2016
    I remember about 10 years ago, I saw an obituary for a guy named (enter first name) "Smutman" (enter last name). I wonder if that was his brother?
    Feb 2018
    I am converting to gasoline bike i want to have better stopping power since its going to go up to 30mph.
    Quote Originally Posted by Jwiffle View Post
    Beach cruiser fork i have is super fat and more reliable than one on road bike, so i cannot see why not.
    People use beach cruiser frames for gas conversion most of the time.
    Oct 2017
    Because what's the worst that could happen, right?
    Hint: It's not good
    Dec 2018
    Cool, man. But I prefer to make a new bike instead of that.
    Reputation: Srode's Avatar
    Aug 2012
    It's stuff like this than makes the Darwinian awards, and would have been a great "Tool Time" episode. I wouldn't do it, no way. A beech cruiser probably isn't safe at 30mph either. Why not just get an E-Bike? Then you know it's designed to do what you want.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Trek Crockett
    Sep 2016
    Well, since he's told us that it's a gasoline conversion, now's the time to tell him that this is NOT a forum for motorcycles. I really think that he should go to Bikeforums.net. It's where he belongs, not here.
    Over there, the 'echo chamber' will reassure him that it IS a good idea, and he can happily ride his ill-conceived death-trap until the day he smashes into a tree at full speed, because of some part failure of his dumb conversion.
    a real member's member
    Jul 2016
    It's stuff like this than makes the Darwinian awards... Why not just get an E-Bike?
    yeah, but i've got an old lawnmower, a beach cruiser and $30 to spend on a good brake and gasoline.
    Sep 2016
    Reminds me of a guy I knew once who wanted to convert his snowblower into a lawnmower....
  1. Disk break conversion.
    By Sasquatch1000 in forum Components, Wrenching
    Last Post: 05-12-2016, 05:21 AM
  2. road (avid) disk brakes?
    By TrailNut in forum Components, Wrenching
    Last Post: 03-06-2015, 03:31 PM
  3. Rear Disk Conversion?
    By tommignon in forum Tandems
    Last Post: 05-06-2010, 08:39 AM
  4. What are your thoughts on this? (re disk brakes)
    By M.J. in forum General Cycling Discussion
    Last Post: 10-19-2005, 09:59 AM
  5. Giant frame, disk brakes, wheels for sale
    By jroden in forum Cyclocross
    Last Post: 08-11-2004, 09:56 AM
