frame sizing for 187cm ridder
Results 1 to 15 of 15
    Jun 2007
    Good day all,
    I had very old ~2006 Original Pinarello Paris frame which I broke.
    Size of the frame was ~58cm.
    I do not have much money checked some frames from china and found some nice frames there.
    But max size of the frame is 55cm.
    Will it fit to me im 187cm ridder?
    Thanks in advance.
    //Nikolaj
    Probably not but there is more to frame sizing than the number assigned to it by the maker so it's impossible to say.
    For example, I'm 5' 8" and the frame that fits me perfectly (custom frame so right one the nose) is called a 51. Lots of people my height are perfect on a 54 as was I on a 54 that has different geometry than my 51.
    Sep 2011
    Aliexpress and alibaba sell a load of different frames so keep looking,
    for example this one has size 59
    https://www.aliexpress.com/item/4000...chweb201603_53
    Never Give Up!
    Mar 2009
    First thing you need to know... All frames are not created equal, as well as sizing.
    I'm 5'.6" and was comfortably fitted on Scott 54" where on Obrea I'm fitted to a 51".
    You best bet is reach out to MFG's and discuss your options directly
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
    Jun 2007
    Im thinking of taking chinarello F10 for ~400 EUR, there are all sizes will take 57.5 like my original Paris is, never tried china carbon frames, im interested are they much worse than original?
    Just that guy had chinarello f8 55 for ~320 EUR, but if it does not fit than I better pay 80 EUR extra.
    I saw some F12 going around, but its very expensive even in china ~640 eur with handlebars.
    Reputation: smokva's Avatar
    Jul 2004
    Quote Originally Posted by pRoto View Post
    Good day all,
    Thanks in advance.
    //Nikolaj
    Today number which is stated as frame size means nothing. It can mean anything and every producer has its own system of sizing.
    You should check and compare reach, stack and seat tube angle....this will give you real idea about size.
    Chainstay length, headtube angle and fork are important for riding characteristics.
    Sent from my SM-G960F using Tapatalk
    Ante Smokrovic
    2009 De Rosa Neo Pro - Fedaia, Giau, Pordoi, Sella, Gardena, Campalongo, Falzarego, Valparola, San Pellegrino, Valles, Staulanza, Vršič, Mangart, Furcia...
    2003 De Rosa Team - Stelvio, Gavia, Mortirolo, Bonette, Agnel, Izoard, Fedaia, Giau, Pordoi, San Pellegrino, Staulanza, Manghen, Vršič, Učka, Mangart, Biokovo, Eisentalhöhe, Schonfeld, Schiestelscharte, Flattnitz...
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Personally, I would not touch them. These small upstart companies simply don't have the resources for the extensive engineering and testing that frames from well known companies have. It isn't like buying a cheap toy. A bike is something that can severely injure or kill you if the frame fails.
    As far as frame sizing, there are too many variables to recommend a size and it doesn't help that the same size from different brands can be quite different. In general, I'm 177cm tall and take a 56cm frame.
    Sep 2011
    Chinese frames today are much better off than compared to even 5 years ago. HongFu make very good frames now, and I'd say they're on par with all mid-level bikes from the big names like Specialized, Cdale, Cervelo. I would not hesitate to buy a HongFu frame today, at all.
    A step up from HongFu is Yoeleo.
    Mar 2006
    You need a 58 cm frame......+/- 1 cm.
    WA outdoor enthusiast
    Mar 2002
    PRoto, I'm your exact height and (measured in the traditional manner assuming level top tube) ride bikes with a seat tube of 59-61cm ctc. Effective top tube of 57-59cm usually works for me, if the head tube is 17cm or greater.
    Of course your inseam, torso and arm measurements may be different.
    Your riding style may be different, your flexibility may be different.
    When looking for value in a good bicycle, buying used is generally the best - if you are patient. Provide your location and maybe Forum members in your area can point you to good bikes for sale locally.
    Good luck.
    Chinese bikes - i've never owned a bike made in China, so no help there.
    NTA
    NTA is offline
    Reputation: NTA's Avatar
    Apr 2010
    I'm 187 tall,I use 56 / 57 sm,depending on who makes frame ...
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by NTA View Post
    187cm is 6' 1.5". Seriously a 56? I'm 177cm and take a 56.
    Oct 2013
    Depends on if your racing and can get low, or want to ride around on a couch!
    I'm more of a couch guy.
    BANNED
    Banned Sock Puppet
    May 2014
    "Couch" is such a perjoritive term, almost as bad as "recreational". I prefer the euphemism "endurance".
    NTA
    NTA is offline
    Apr 2010
    Yas,now i have Canyon frame 56,but Pinarello I used 57 and 57.5
  1. Wheel Sizing, Frame Sizing - Help
    By cory15000 in forum Bikes, Frames and Forks
    Last Post: 04-19-2013, 04:18 PM
  2. frame sizing Cervelo groupie vs TT frame
    By velocardin in forum Bikes, Frames and Forks
    Last Post: 08-31-2010, 02:10 AM
  3. "fun" wheels for heavy ridder
    By golfernut78 in forum Wheels and Tires
    Last Post: 02-23-2010, 05:39 AM
  4. 1st Roadie for 187cm/6"1 87kg/190lbs MTB'er
    By Australia in forum Beginner's Corner
    Last Post: 05-11-2009, 11:03 AM
  5. frame fit: road bike and mtb xc frame sizing
    By avery05 in forum Bikes, Frames and Forks
    Last Post: 05-11-2006, 09:59 AM
