head tube length?
Results 1 to 6 of 6
    Reputation: AlexCad5's Avatar
    Jan 2005
    head tube length?
    How does head tube length/height effect a bikes performance?
    Reputation: Nessism's Avatar
    Quote Originally Posted by AlexCad5
    A long head tube makes it easier to get the handlebars up without excessive use of spacers.
    Feb 2002
    Single variable in the matrix
    Per Nessism's comment, it raises the handlebars without using spacers. Otherwise, it is just one variable in many that must be put together to determine the overall performance of the bike. That said, you can have all kinds of geometries and dimensions, and any one of those can have varying head tube length without affecting the performance in any signfiicant way. Except, of course, if the longer head tube forces the rider into a more upright position that can't be corrected with stem choice.
    Jan 2003
    Quote Originally Posted by Kerry Irons
    i don't know if they are still around but thise track stems w/ a lot of negative rise would make any bike low enough.
    i always heard "buy your road bike slightly big never small.." i see bikes posted here that are clearly too small. a too short wheelbase won't be corrected w/ long or uprise stems.
    www.flaviocolker.com.br
    i am in love w/a black woman.
    Jan 2005
    Quote Originally Posted by colker1
    Interesting. I have historically ridden bikes that were too big for me. My last steel bike had a top tube that was right at my pelvic bone when I stood over it. I mounted it like a horse, rather than like a bike. My (now former) Cannondale was, I now know, too big (a 56) My Look 231 feels right at 55cm. I bought a Fuji Pro last year for the DA 10 parts, and as a whim bought a 54 to see how that rode. (Very well but stiffer/harsher than I would like, so I sold off the frame.) That brings me to the Motobecane which I bought, partially as a build kit and partially as something I could race without worrying about pretzeling it. Again a 54cm.
    However, this frame is much different than the Fuji, and feels small/short. The headtube is very short, causing me to need a shorter stem than on the Fuji (which had a semi-sloping t-tube.) My concern is that maybe I have too much weight over the front of the bike, and maybe, in some situation, I could more easily go over the handlebars, which indirectly speaks to Colker1's assertion that the wheelbase on a bike that is too small will be too short. (?)
    I've needed to put a 350mm seatpost on the bike to make it fit. In the drops, I can see the fork over the handlebars, though that is not the case on the hoods.
    Jan 2003
    Talking
    the only bike you can buy small is colnago. the lax head tube makes for a longer fornt center and longer wheelbase. then you buy it using c- t as c-c. you ride a one size smaller w/ a longer stem and get the same wheelbase. plus all the cool points.. no wonder colango si so ppopular. it fits w/ the times and our long seatpost mentality. maybe it's also a great bike
  1. head tube angle and head tube height affect fit
    By fah35 in forum Bikes, Frames and Forks
    Last Post: 04-24-2005, 04:01 PM
  2. Does Head Tube Length have a bearing on fit?
    By eb in forum General Cycling Discussion
    Last Post: 11-29-2004, 02:40 PM
  3. Frame height vs. top tube length -- which is more important?
    By wilburpan in forum General Cycling Discussion
    Last Post: 07-22-2004, 08:04 AM
  4. Frame stiffness?
    By JAM66 in forum General Cycling Discussion
    Last Post: 06-09-2004, 10:13 PM
  5. relation between top tube length vs. stem length
    By NoMSG in forum General Cycling Discussion
    Last Post: 03-20-2004, 05:29 PM
