Help Understanding the Numbers
Results 1 to 9 of 9
    Reputation: PBL450's Avatar
    Apr 2014
    Hi all, Iíd love feedback/help comparing two sets of frame dimensions. One, pictured (I can never get he picture function to work right, apologies in advance) vs the data I have on a bike Iím interested in.
    Interested:
    • Seat Tube Length: 50cm
    • Effectvie Top Tube Length: 58.1cm
    • Head Tube Angle: 73.5 degrees
    • Set Tube Angle: 73 degrees
    • BB Drop: 7cm
    • Chainstay Length: 40.5cm
    • Top Tube Slope: 8 degrees
    • Estimated Front Center: 59.7cm
    • Head Tube Length: 16.8cm
    • Head Tube Diameter: 1 1/8Ē
    • Seatpost Diameter: 27.2
    • Estimated Standover: 80.4
    To date, philosophers have merely interpreted the world in various ways. The point however is to change it.
    Apr 2014
    Struggling to make that post work so Iíll continue with another post... pardon the inconvenience. Obviously materials and many other factors are involved, but given the available data what can we know about the key differences between the two bikes? Any feedback is much appreciated!
    Schuylkill Trail Bum
    Reputation: SPlKE's Avatar
    Sep 2007
    Quote Originally Posted by PBL450 View Post
    Your post looks fine to me. The diagram is embedded and I can see it without clicking on the link that's there.
    Apr 2014
    Quote Originally Posted by SPlKE View Post
    Thanks,! Iím trying to see what differences in ride and handling can be gleaned from the dimensions above vs the dimensions of my current bike pictured below.
    Feb 2002
    Interested:
    • BB Drop: 7cm
    Sorry, but I am not going to take the time to create a parallel table with all the measurements taken from the diagram. I suspect few others will either. How about you create the list of numbers for each frame so readers can easily compare them?
    Cycling induced anoesis
    Reputation: PJ352's Avatar
    Dec 2007
    The differences that would likely be discernable (IMHO) are:
    ETT is ~3 cm's longer on the bike you're interested in. STA only changes by .5 cm, so fore/ aft saddle position would likely be similar, so think about changes in reach and requisite stem length change.
    HTA is ~1 degree more on the bike of interest, so assuming a fork rake of ~45 degrees, steering will be quicker.
    HTL is just under 1 cm taller on the bike of interest. All else being equal (spacers, stem angle) bars *may* be a bit higher on that bike.
    Wheelbase is slightly shorter on the bike of interest - also quicker handling.
    While stand over (IMO) isn't really a fit parameter, I like to be able to straddle a bike, so if it matters to you, the difference is 80.4 versus your current 77.4.
    Russian Troll Farmer
    Sep 2016
    Seat tube is too long......
    "L'enfer, c'est les autres"
    Apr 2014
    Quote Originally Posted by PJ352 View Post
    Thank you, I appreciate your reply. The relationship between the longer ETT and shorter wheelbase is something I am interested in... The bike Iím interested in was a custom frame ( I think), so there isnít a frame diagram to compare apples to apples. The data that is there is what he seller supplied. I use a 125 stem with zero set back now so that difference could be absorbed with any fuss. Both bikes are a size 58. 3 extra cm standover shouldnít be a problem. Again, thanks for your reply!!
    Apr 2014
    Thanks NTT, am I reading something wrong? Iím riding a 49 and the new one is 50?
  1. Help understanding Cassette differences
    By dturner in forum Components, Wrenching
    Last Post: 01-05-2008, 06:29 AM
  2. Help understanding Road Bike Components
    By incognito_54 in forum Beginner's Corner
    Last Post: 09-12-2007, 09:06 AM
  3. Help understanding Merckx geometry
    By jroden in forum Merckx
    Last Post: 06-28-2006, 09:28 AM
  4. Help understanding bottom bracket fit
    By jroden in forum Components, Wrenching
    Last Post: 12-21-2005, 07:20 PM
  5. Please help w/ understanding gear ratio...
    By coldplay in forum Components, Wrenching
    Last Post: 08-15-2004, 12:14 PM
