Kinesis Athein Evo Frame-set ?
Results 1 to 12 of 12
    Oct 2013
    Hi All,
    I'm thinking of buying a Kinesis Athein Evo Frame Set; they get excellent reviews; but, I read that the front mech position will only accommodate a 52/36 chain set; and I wanted to use a compact 50/34 C/Set on the frame.
    Does anyone know if this is correct or can a 50/34 be used on the frame? I cannot find anything about it on the Kinesis Web-site.
    'brifter' is a lame word.
    I'd find that hard to believe given the percentage of people riding compacts. Why don't you just email them and ask directly?
    I work for some bike racers
    and a bunch of skateboards
    Oct 2002
    Quote Originally Posted by Fredrico View Post
    It's full of factual errors. :nono:
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    https://www.kinesisbikes.co.uk/Catal.../Aithein-EVO-2
    "Please Note: Minimum 52t front chainring."
    I'll be damned.
    Oct 2002
    I don't find this surprising at all. It's a racing bike. If the rider needs a bailout gear they can throw one on the rear cluster. Did roads get steeper since the days I was racing or did something else change?
    Jan 2005
    Quote Originally Posted by kiwisimon View Post
    Depends on who makes you cassette. For years Campagnolo adamantly has refused to make a rear cluster with a bailout cog larger than 29T....I think with 12 speed they finally added a 32T.
    Oct 2002
    36X29 is still pretty low gearing but point taken.
    Sep 2011
    I'll be damned.
    my Casati Inox requires a 52 mininum chainring too due to the high positioning of the front mech tab. And that's fine with me. But this also unnecessarily limiting. What I don't understand is:
    1. why can't they make the der tab a bit longer to accomodate 50-53 rings?
    2. in my case, the seat tube is... round! Why even bother welding a der tab?? why not just let the user use clamp?
    Things that baffle me
    Reputation: velodog's Avatar
    Sep 2007
    Sugino makes this front derailleur adapter to allow the front derailleur to be mounted lower to allow the use of the smaller chainrings of a sub-compact crank.
    https://www.suginoltd.co.jp/us/produ...html#pnH4MT-OX
    The PDF manual in the link shows it mounted.
    Too old to ride plastic
    May 2012
    I'll be damned.
    You shouldn't have to, but couldn't you rat tail file the lower tab slot radius to allow a few more mm lower mounting?
    Quote Originally Posted by Bremerradkurier View Post
    Yes, I have done that in the past.
  1. Replies: 1
    Last Post: 10-03-2013, 05:33 AM
  2. Kinesis Crosslight 5T frame?
    By Durt in forum Cyclocross
    Last Post: 12-30-2011, 04:18 AM
  3. Kinesis aluminum fork: opinions?
    By fiddledoc in forum Components, Wrenching
    Last Post: 03-04-2007, 03:33 PM
  4. Kinesis frames in US?
    By lvrvrs in forum Cyclocross
    Last Post: 03-21-2006, 10:51 AM
  5. Perf. Axis Pro fork = Kinesis Saber?
    By ckilner in forum Bikes, Frames and Forks
    Last Post: 10-04-2004, 11:45 AM
