Most Gears for Vintage Bikes
Results 1 to 15 of 15
    Sep 2018
    I have a few vintage bikes (1987-1989) and want to find out what the maximum gearing I can run is. If I understand, these bikes have 126mm dropouts, vs the new standard of 130mm. What is the maximum number of gears I can run in the back with this setup? (I think 7, but want to check).
    What options exist for derailleur and integrated brake/shift levers? I have SRAM Force (2010 vintage) on a newer bike and would love to have these newer components on one of the older frames. I don't believe all the gears are necessary on the new bikes, just not sure the new integrated brake/shift levers and derailleurs can run as they should with fewer gears than they were designed for on a narrower-spaced stay.
    Thanks in advance for replies.
    Jul 2011
    In short, I think a 7sp freewheel is the widest you can run w/o stretching the frame:
    https://www.sheldonbrown.com/cribsheet-spacing.html
    I ran 3x6 on my '74 Schwinn for many decades (120mm rear spacing was 2x5 originally):
    https://www.4crawler.com/Photos/104_pana/Schwinn/8.html
    Then went to 3x7 for a few years:
    https://www.4crawler.com/Photos/104_pana/Schwinn/9.html
    Then finally went to 3x10 on a 130mm hub and that worked fine. The frame had already sprung out to around 126mm with the 7 speed freewheel:
    https://www.4crawler.com/Photos/104_...chwinn/11.html
    It was easier to fit the 10sp cassette than the 6- or 7-sp freewheels as they had 13T small cogs that caused the wider chain to rub on the stays while the 11T on the 10sp cassette was small enough that the narrower chain cleared the stays. I run friction shifters on that and didn't have to change those. I didn't set the frame either, just spread it a little to squeeze the hub in place.
    On my new cross bike, I run the Retroshift/Gevenalle brake/shifter combo. With the, you just match up an indexed bar end shifter to the freewheel or cassette with the same generation RD and that should work. On mine, I have a 9sp MTB RD and a 10sp indexed road bar end shifter and that combination works a treat:
    https://www.4crawler.com/Photos/104_pana/CX700/3.html
    I haven't run any of the newer integrated shifters myself. I think if the cable pull ratio of the shifter and RD match up, you can set the limit screws to stop it from over shifting.
    Feb 2002
    Quote Originally Posted by mml373 View Post
    Steel frames can easily be spread to take wider hubs. I had a frame that "took a set" after a few thousand miles of riding with a slightly wider hub in it - I didn't spread the frame other than to squeeze the hub in, and after a while I didn't need to spread it. Aluminum frames don't take kindly to such treatment. A frame from the late 80s was made for 6 or 7 speed.
    Sep 2018
    Appreciate the replies, all. Sounds like spreading the stays on one of the vintage frames might be a way ahead.
    Reputation: Fredrico's Avatar
    Jun 2002
    Or slap a 13-28 six speed freewheel on it [about $25], down tube friction or 6 speed click shifters. With 52-39, that bike will go anywhere, no problem.
    Apr 2014
    This guy has a great channel for all things bike.
    https://youtu.be/YdibmxBuMy0
    Reputation: Kuma601's Avatar
    On a steel frame you have options as mentioned above and is an easy update. I've seen a guy running 10spd Chorus on his Vitus 979 but I wans't that brave to attempt that for mine so it remains a 6spd.
    6spd down tube shifters are off-on finds. The Exage to me shifts pretty nicely and at those levels the prior owners were casual types so not as much use and prices decent. The SIS capable 105 and 600 are getting to be $ in good shape. NOS I've seen north of $70. With those prices on a steel frame may as well update to 9 or 10spd.
    Eye of the Bobke
    Reputation: Mike Overly's Avatar
    Sep 2005
    I did the unthinkable and spread the stays on one of Ernesto's early 80s classics to put Campy 10 speed on. No issues after 15 years on the setup, though I did have to give up the smallest sprocket because of chain clearance limits.
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by Kuma601 View Post
    Another option would be a set of Simplex Retrofriction shifters. They're the smoothest friction shifters I've ever used.
    Too old to ride plastic
    Sep 2007
    Quote Originally Posted by Mike Overly View Post
    If it kept you riding the bike, not so unthinkable. I did it to one of my DeRosa's, with no chain clearance issues.
    Jun 2002
    Beautiful! Period correct, too!
    Jun 2002
    Would that be the 11 t. outer cog? With 52/42 rings? Does any rider actually push that gear under power for any length of time? . Good riddance.
    Russian Troll Farmer
    Sep 2016
    I remember that Sheldon Brown managed to put a 7sp cassette on a 3-speed Sturmey-Archer internal 3-speed, and used a triple ring crank, to get a total of 63 speeds. Probably a record....
    "L'enfer, c'est les autres"
    Eye of the Bobke
    Sep 2005
    Quote Originally Posted by Fredrico View Post
    Yep. And not me. Not nowadays
    'brifter' is a lame word.
    Unthinkable? It's just a bike no matter who made it.
    I work for some bike racers
    and a bunch of skateboards
  1. And most, most definitely, don't do this
    By pmf in forum General Cycling Discussion
    Last Post: 06-25-2018, 12:30 PM
  2. Replies: 8
    Last Post: 06-16-2015, 06:44 PM
  3. Replies: 26
    Last Post: 07-02-2007, 09:54 PM
