Painting a fork
Results 1 to 6 of 6
Thread: Painting a fork
    Mar 2012
    Painting a fork
    Do I risk damaging the fork by sanding the paint down so it can be painted?
    I am able to get a good deal on a brand new fork for my bike off ebay, just the color does not match. I would just be painting it a solid black. I would be worried about damaging it whiling prepping it to be painted.
    Any concerns or suggestions
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by sheepherder View Post
    If you do it wrong maybe.
    If you do it right, no.
    Lightly sand (by hand) enough to remove the gloss coat. Then paint.
    Reputation: ogre's Avatar
    Dec 2005
    First question. What's the fork material?
    Jul 2012
    Google and You tube is your friend. There are many sources out there that show you how properly sand and paint stuff like this. Unless anyone here does this kind of work, they can't help you and would only be guessing. There are resources out there because I've searched in the past.
    Mar 2012
    Quote Originally Posted by ogre View Post
    Carbon
    Never Give Up!
    Mar 2009
    Sand with very fine wet/dry sand paper while using a spray bottle of water, use a light touch while sanding... just enough the dull out the current paint/finish but enough so the new paint as something to hold on too.
    After applying the first coat, re-sand very lightly again with the wet/dry paper and water, apply another coat and repeat until you have the desired finish your looking for... the same principal goes for the clear coating... spray/wet sand/spray/wet sand/spray etc.
    2010 Orbea Onix w/Ultegra R8000
    2007 IRONHORSE HT
  1. painting carbon fork
    By gr8blues in forum Components, Wrenching
    Last Post: 04-28-2010, 07:50 PM
  2. MXL fork painting update
    By innergel in forum Merckx
    Last Post: 05-05-2008, 05:34 AM
  3. Painting a fork to match a frame
    By innergel in forum Bikes, Frames and Forks
    Last Post: 03-07-2008, 11:10 AM
  4. painting without taking fork/headset out?
    By iherald in forum Fixed/Single Speed
    Last Post: 01-19-2007, 08:34 PM
  5. Painting a carbon fork
    By lemond111 in forum Bikes, Frames and Forks
    Last Post: 12-26-2006, 06:31 PM
