Specialized - S-Work Tarmac vs. Tarmac Pro (both SL4 and 2014)
Results 1 to 5 of 5
    Oct 2013
    What is the primary difference in the top of the line Specialized Pro vs. S-Works. I've narrowed the bike down to the 2 of these. What do you think?
    Aug 2010
    The S-Works frame is about 75-100g lighter. Other than that, and the bling-factor of S-Works, probably no perceptible difference in the way they ride. If you're buying just the frame the S-Works is only $550 more which is not that much when you're spending $5k+ on a complete bike.
    S-Works Tarmac SL3
    Reputation: NealH's Avatar
    May 2004
    I have heard some say the S-Works is just a touch livelier due to the slight bit more resin squeezed out during the carbon prep of Fact 11R. But this is hard to quantify. I believe the 11R frame (S-Works) measured a little stiffer in some areas during testing. This data used to be on the Specialized website but I have not looked recently. In any event, the two frames are very close and I seriously doubt you or I would ever be able to tell the difference blindfolded. So the S-Works is lighter and stiffer but, the law of demising returns is probably at hand.
    Dec 2013
    I heard that the S-Works is lighter. Certainly no perceptible difference in the way they ride. BTW, the frame(11R S-Works) is so good.
    Still waiting......
    I picked up an Sworks frame/fork last year and built it up. Friend has the same size/year/model non-Sworks (pro?). We have relatively similar wheels Fulcrum Racing 1's vs Campy Eurus.
    We've traded off bikes on a few rides. Neither of can tell any difference.
    IMHO - unless you're getting a screaming deal on the Sworks, save your money.
    AKA - Go Dot
  1. Specialized Tarmac Pro 2013 vs 2014
    By mepim in forum Bikes, Frames and Forks
    Last Post: 12-03-2013, 07:21 AM
  2. 2014 Tarmac Specs
    By bmajik in forum Specialized
    Last Post: 07-10-2013, 12:56 PM
  3. 2014 Tarmac with Ultegra 6800 11-Speed!
    By krtassoc in forum Specialized
    Last Post: 06-22-2013, 05:38 PM
  4. Specialized Tarmac SL3 vs. Tarmac SL3 Pro
    By mbnakron88 in forum Bikes, Frames and Forks
    Last Post: 01-30-2011, 07:58 AM
  5. Replies: 5
    Last Post: 10-16-2007, 05:34 PM
