What frame is taller, yet has shorter top tube?
Results 1 to 2 of 2
    Lactic Acid Life
    Reputation: Squishy's Avatar
    Nov 2001
    I was put on a "size cycle" and the measurement of my perfect frame would be 57cm down tube and 55cm top tube (both c-c).
    I cannot afford custom. Is there a maker that typically makes a taller/shorter frame? Should I just split the difference and find a 56x56 and change out the stem?
    May 2004
    Research what you can. My Basso has a top tube just slightly shorter than the seat tube, while my buddy's Masi is longer in the top tube. Just look at the geometry of the frames you're interested in, and make up the difference with the stem.
  1. KG 486 SL Jalabert!
    By francois in forum Look
    Last Post: 06-13-2004, 09:06 AM
  2. Frame stiffness?
    By JAM66 in forum General Cycling Discussion
    Last Post: 06-09-2004, 10:13 PM
  3. campy cable housing with top tube routing
    By jnichols959 in forum Cyclocross
    Last Post: 05-01-2004, 05:12 PM
  4. Looking for Frames with a Long Top Tube
    By barrettmcmurtry in forum General Cycling Discussion
    Last Post: 04-21-2004, 07:19 AM
  5. relation between top tube length vs. stem length
    By NoMSG in forum General Cycling Discussion
    Last Post: 03-20-2004, 05:29 PM
