Wilier Izoard XP
Results 1 to 6 of 6
    Sep 2004
    Wilier Izoard XP
    Anyone with experiance on the Wilier Izoard XP? I've looked for reviews, but I'm coming up a little short. I understand the 2011 added some weight with some frame changes. I was wondering how the ride is and if it's reasonable to build a 16 lb bike with this frame. Thanks!
    Reputation: xjbaylor's Avatar
    Dec 2006
    Quote Originally Posted by lamazion View Post
    Even starting with the Rival build from Competitive you should have no trouble building a sub 16lb. bike. You could likely do it with nothing but a new set of wheels/tubes/tire.
    Every review I have seen has been positive, even for the newer one which, as you said, has a slightly lower end carbon weave and an alloy steerer.
    Sep 2004
    In the link above, several people have mentioned the Rival build coming in at 19lbs. Ouch! Will be hard, and expensive, to get that down to the 16 lb range. The advertised frame and fork weight must not be correct.
    Jun 2010
    Stats say frame is 1170g and fork is 490g....get to work!
    May 2011
    I thinks willier full with Italian emotion which costs you $700 extra, in Europe there are many German standard bikes who delivers more for the same price.
    These bikes are in most cases lighter than the izoard.
  1. Wilier Izoard, What can you tell me...
    By Har in forum Other Builders
    Last Post: 10-21-2011, 08:47 AM
  2. Wilier Izoard vs...
    By Mustang2011 in forum Bikes, Frames and Forks
    Last Post: 06-02-2011, 12:44 PM
  3. Looking for a New Frame BH G4 or Wilier Izoard
    By acidzerocool in forum Bikes, Frames and Forks
    Last Post: 06-11-2010, 03:41 PM
  4. Wilier Izoard on the way!
    By wsrobert in forum General Cycling Discussion
    Last Post: 05-06-2009, 05:26 PM
  5. Wilier Izoard or Colnago CLX?
    By Dolamite in forum Bikes, Frames and Forks
    Last Post: 07-20-2008, 07:00 AM
