10-speed cranksets
Results 1 to 4 of 4
    Sep 2008
    10-speed cranksets
    I have two road bikes, both with Campagnolo Record/Chorus 10-speed components from 2002 (square taper BB/crankset) and 2006 (Ultra-Torque). I am trying to find a new, 10-speed, compact double (50/34) crankset preferably with 172.5 mm crank-arms but I have a very limited number of choices.
    New Record or Chorus UT 10-speed cranksets seem to be unavailable. Conventional wisdom appears to be that (1) An 11-speed would probably work with my otherwise 10-speed drivetrain. (2) Donít mess with either Over-Torque or Power-Torque inferior options.
    Right now, based on on-line availability, I might have to settle for a Centaur Ultra-Torque but with 170 or 175 crankarms and, sadly, with 53/39 chainrings.
    Any other thoughts? Thanks for any advice. William (Austin, Texas).
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    Get an 11 speed UT crank. I find the 11 speed cranks shift better than the 10 speed cranks with a 10 speed chain. The finish on the 11 speed chainrings is also a whole lot tougher than the 10 speed ones. They are 100% compatible. Merlin has what you want:
    https://www.merlincycles.com/campagn...eed-79613.html
    I have three 10 speed bikes with 11 speed cranks, I actually sold off the 10 speed cranks years ago that's how much better the 11 speed cranks are.
    ďBicycling has done more to emancipate women than anything else in the world.Ē - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
    hfc
    hfc is offline
    Doesn't like subtitles
    Reputation: hfc's Avatar
    Jan 2003
    Iím using a Velo Orange compact crank on a Centaur 10 speed set up and Iíve used an FSA compact pro elite for years on 3-4 different bikes with 10 speed. Currently on my cross bike with Chorus 10. I have an IRD Defiant crank on an 8 speed set up but I think itís marketed for use as 10 speed.
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by hfc View Post
    I'm using an IRD Defiant on an 11spd Chorus drivetrain and it works flawlessly.
    Too old to ride plastic
  1. Replies: 6
    Last Post: 04-22-2020, 04:15 AM
  2. Replies: 7
    Last Post: 05-05-2015, 10:51 AM
  3. SRAM 22 cranksets on a 10-speed setup?
    By AJ88V in forum Components, Wrenching
    Last Post: 10-05-2013, 06:09 AM
  4. Replies: 5
    Last Post: 06-23-2011, 01:33 PM
  5. Record 10 speed carbon cranksets
    By amicus in forum Campagnolo
    Last Post: 04-17-2009, 10:41 AM
