10spd chain on 11spd record crankset
Results 1 to 5 of 5
    Reputation: nismosr's Avatar
    Jun 2007
    Will 10spd record chain work on 11 SPF crankset?
    Sep 2003
    don't think so 10 spd chain is 5.9mm and 11 spd is 5.4mm.
    My next vehicle would be a zamboni
    2012 Super Six (Chorus 11)
    2011 Super Six Team edition (Super Record 11)
    2009 Super Six HM (Super Record 11)
    2007 Systems Six (Record 10)
    2008 Caad 9 (Centaur 10)
    2004 Caad 7 ( sold )
    2000 Caad 3 ( sold )
    Nov 2008
    Depends on what you're trying to do. If its a 10sp drivetrain that you want to put 11sp cranks on then there is a chance it will work.
    If its a 10sp chain on 11sp drivetrain then it will be too wide
    info...
    Quote Originally Posted by nismosr
    As noted, the 10 speed chain won't work with an 11 speed cassette, but it will work with the crank. The only possible problem is increased chain rub when cross chaining. With a compact, the little ring and second cog should be useable, but with a wider chain you might get some rub. The little ring and first (smallest) cog should never be used.
    Jun 2007
    Thanks guys ..ended up buying a record 10 crankset instead to avoid any problem.
