2015 campy rings
Results 1 to 3 of 3
    Reputation: triumph.1's Avatar
    Jun 2011
    2015 campy rings
    I can't seem to locate a source for the newer four arm Campagnolo chainrings. Ebay has a few, but not much choice. Anyone know of a reliable online dealer?
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    Finding the genuine article Campag chainrings online is tricky especially if you want legit looking storefronts.
    TA makes 4-bolt 145/112mm BCD 11speed Campag rings. Wiggle sells them as probably do others: Wiggle | Chainrings
    Specifically:
    Wiggle | TA X145 Campagnolo 11 Speed 50T Outer Chainring | Chainrings
    Wiggle | TA X112 Campagnolo 11 Speed 36T Inner Chainring | Chainrings
    Amazon sellers also list them...to find the listings search for "Campagnolo chainring 145BCD" or "Campagnolo chainring 112BCD"....unless your search string includes the BCD spec you won't find them, as you probably found out.
    Amazon.com : Campagnolo FC-SR350 50t 11s Chainring : Sports & Outdoors
    Amazon.com : Campagnolo 2015+ SR Re Ch 2x11sp chainring 112BCD- 34t : Sports & Outdoors
    The above listings are via ExcelCycles which should be legit...and genuine Campag replacement parts.
    Jun 2011
    Thanks Marc, great info. I found both the 52 and 36t on Amazon.
  1. Campy and Q-rings ?
    By Adrianinkc in forum Campagnolo
    Last Post: 01-02-2014, 07:30 AM
  2. Q rings -Campy / Shimano
    By cantride55 in forum Components, Wrenching
    Last Post: 12-06-2010, 06:41 PM
  3. Campy Cross Rings
    By lousylegs in forum Cyclocross
    Last Post: 10-05-2009, 11:57 AM
  4. Cyclocross Rings for Campy CT?
    By Dave in Driggs in forum Cyclocross
    Last Post: 10-31-2008, 10:15 AM
  5. Salsa 8/9s rings OK for Campy 10s?
    By SDizzle in forum Components, Wrenching
    Last Post: 04-06-2006, 05:39 AM
