Campagnolo Flatbar Shifters
Results 1 to 24 of 24
    Dec 2009
    I bought some Veloce flatbar shifters. Is anyone using these? Do I really need to hunt down a Flatbar Front mech or can I use a QS mech? I have heard conflicting answers. Thanks for any info in advance.
    cs1
    cs1 is offline
    Reputation: cs1's Avatar
    Sep 2003
    I've been wanting to try a set for a couple of years. Who has them in stock? None of the UK sellers seem to have any interest in them. US sellers say nobody wants them. Shimano is selling a whole lot of their FB shifters.
    Dec 2009
    I bought a new set off ebay.. 150..
    Jan 2010
    Quote Originally Posted by ComesAtime
    I've been an ebayer for 5 yrs now and have only seen FB FD come up once. I believe the only difference was slightly more leverage. The short answer is that you may not have much choice but experimenting with either QS or the more recent "universal" 10 spd model FD
    Jun 2005
    I think the veloce flat bar FD is a top pull FD (like a mountain bike) I don't know if that means the shifters won't work with a road FD or not....
    Fighting C ystic F ibrosis with C arbon F iber
    Learn More about CF here: www.cff.org
    Jan 2010
    Quote Originally Posted by Topher
    No, they looked very much like a conventional FD. you can research on the campy parts site and see.
    Jan 2010
    I got home & checked. p 43 of the 2006 parts manual (online at the campy site) shows a pic with a conventional looking FD but with a longer arm.
    Sep 2003
    This is my setup and you must use the QS FD in order to work with FB shifters.
    My next vehicle would be a zamboni
    2012 Super Six (Chorus 11)
    2011 Super Six Team edition (Super Record 11)
    2009 Super Six HM (Super Record 11)
    2007 Systems Six (Record 10)
    2008 Caad 9 (Centaur 10)
    2004 Caad 7 ( sold )
    2000 Caad 3 ( sold )
    Reputation: Quattro_Assi_07's Avatar
    Jan 2006
    I love my SRAM Double Tap flat bar shifters.
    Another type you might want to try.
    San Antonio, Texas
    Dec 2009
    Quote Originally Posted by Quattro_Assi_07
    No, I wouldn't..
    cs1
    cs1 is offline
    Sep 2003
    SRAM looks nice but I don't think the 1:1 will interface with a Campy drivetrain. In my case I've got Campy on all my bikes. I'd loose my shirt selling it off and using SRAM.
    Dec 2009
    Quote Originally Posted by bikerjulio
    there are 2 sets up right now.
    http://cgi.ebay.com/ERGOPOWER-Campag...item5d2829fb59
    cs1
    cs1 is offline
    Sep 2003
    Do they really need a special front der?
    Sep 2003
    Correct you need to have the QS FD otherwise it will have difficult shifting from middle to big rig chainring.
    Dec 2009
    Quote Originally Posted by zamboni
    I'm using a non QS and it works perfect. It's on a double though.
    cs1
    cs1 is offline
    Sep 2003
    That bike is so nice.
    Sep 2003
    But not for a triple sharp looking bike.
    Dec 2009
    Quote Originally Posted by cs1
    It's a love hate for people. I love it as well.
    Feb 2010
    i love it too~~
    Bianchi-Campagnolo
    Reputation: kbwh's Avatar
    Late to the party, but anyway: That's beautiful, ComesATime.
    Nov 2008
    Hi
    I use these as well on one of my bikes.
    I have four other flat bar road bikes all with different groups so I can perhaps offer a little perspective
    The shifting
    The Campagnolo shifters are odd. They have a slightly longer learning curve to use because the action is Push/Pull and uses the thumb and fore-finger rather than just the thumb but once you figure them out the push/push on MTB systems seems really odd. So I guess I would say they grow on you. Other than the push/pull mechanism they really perform well. What you get for this oddness is the ability to change three gears at a time rather than one in back
    The shifting throw is different on the Campy units. This is really neither bad nor good but it takes some getting used to.
    Other Oddities
    If you use a triple you must have either a Campagnolo QS derailleur OR an old Shimano Deore. When I ordered the parts for the bike with the Campy flat bar some of the parts didn't come in so rather than wait I dipped into the dead parts box and a Deore FD was the only one that could be made to work. I don't know why the Deore worked but it did, however, the cage required quite a bit of, shall we say adjustment.
    Even with the proper derailleur and a Campy crank the front is a little persnickety to get adjusted right but once dialed in it works well.
    That said the shifting is precise and quick, they don't miss shifts and they seem to be reliable
    What Campy got right
    The brake levers just work tremendously well. Good feel not mushy, long enough very solid.
    This may sound trivial but the gear indicators are very well placed. I have used several other brands and the indicator window was always difficult to see. The gear indicator on Campy flat bar units is easy to read and doesn't get hidden under the bar
    Once you get used to the Push/Pull system these things shift really well. Very fast easy to use.
    What they got wrong
    There is no quick release on the brakes which means you need to get another brand brake
    The pull trigger to take the chain to a smaller sprocket could be three or four mm closer to the brake lever or possibly a little bit longer. It is a bit difficult to reach
    I would have split the shifter from the brake
    Be Careful
    There are two versions of these shifters. One for Cantilever brakes and one for caliper brakes
    Just for reference the flat bar bikes I have:
    Soma San Marcos WE/ Veloce -10 speed
    Sam Hillborne w/Suntour XC-Pro-8 speed
    Vitus Stag w/Campagnolo Bullet - 8 speed
    Unknown Aluminum frame W/Microshift - 9 speed
    Mongoose Utility bike W/SRAM 8 speed
    Fai Mao
    A Proud Retrogrouch
    cs1
    cs1 is offline
    Sep 2003
    Quote Originally Posted by Fai Mao View Post
    Be Careful
    Caliper and cantilever should use the same lever. Did you mean Linear Pull V-Brakes? I think that's what the box is marked. If you search old parts diagrams there are 2 different levers available as spares.
    1995 Waterford 1200
    1999 Waterford RSE-11
    Plus a host of old bikes too many to list.
    Nov 2008
    Quote Originally Posted by cs1 View Post
    Yes I meant V-Brakes
    Fai Mao
    A Proud Retrogrouch
    Jun 2017
    I installed this flat bar set up on my wife's bike a while back. The problem I'm having is inconsistent shifting from the middle ring to the big ring. Sometimes it works, other times not. In one of the earlier posts it mentioned using a QS FD (Record) front derailleur, other wise there will be shifting issues going from the mid to the big ring.
    I'm using the QS Record derailleur circa early 2000, is there another fd I should be using?
