Campy UT Record Cranks with shimano shifters and cassette..
Results 1 to 5 of 5
    Aug 2006
    Hi guys,
    I have a question. One of my friends has a new campy record crankset for sale. My bike is assembled with a full shimano 10 speed dura-ace group (except for a FSA SLK double Crankset, 50-34). Is it possible to use the campy cranks with the shimano shifters and shimano cassette ?. Any of you have any experiences regarding this ?.
    I would really appreciate your comments and suggestions. Many Thanks.
    Cheers,
    Vizcaino.
    sure...
    A crank is a crank. All 10 speed models have nearly identical chainring spacing and use the same width of chain, so the brand makes no difference.
    Aug 2006
    Thanks.
    Quote Originally Posted by C-40
    May 2005
    Assuming the chainline measurement is the same for Shimano & Campagnolo of course.
    43.5mm
    Quote Originally Posted by yanksphan
    Never seen one that didn't list the same 43.5mm dimension to an unmeasureable point in between the chainrings. A dimension that can be measured is 48mm to the tip of a tooth on the big ring.
    http://bike.shimano.com/media/techdo...9830605111.pdf
