Ergo lever rattle, help!
Results 1 to 3 of 3
    May 2004
    hi all. i have the first generation 10spd record carbon ergo levers, which have been wonderful for the 3.5 years i've owned them. in the last 2 weeks or so, i've noticed a buzzing type rattle coming out of the left lever. It seems to be predominantly when i'm in the small front chainring, and only when going over cracked pavement (ie not constantly). Any idea what this might be?
    The shifting and braking are as good as day one, and the lever hasn't moved on the bars or anything.
    thanks,
    brian
    May 2002
    Perhaps the rubber stop in the back of the brake lever has become unseated or worn down.
    Squirrel Hunter
    Feb 2003
    Cable Stretch?
    Quote Originally Posted by velodoom
    Could your cable tension be loose? When in the small chainring reach under the downtube and see if it has some tension or is loose enough that it would allow the head of the cable to rattle in the lever.
  1. changing brake reach
    By J dubya in forum Components, Wrenching
    Last Post: 10-04-2004, 06:30 PM
  2. Rattle in Shimano aero brake lever
    By PdxMark in forum Components, Wrenching
    Last Post: 09-07-2004, 02:38 PM
  3. Difficulty reaching brakes in drops
    By jumpin_joe in forum Components, Wrenching
    Last Post: 07-30-2004, 07:28 AM
  4. Big 'Hoods, Little Hands
    By Beantown in forum General Cycling Discussion
    Last Post: 04-26-2004, 12:01 PM
  5. short reach campy levers...
    By C-40 in forum Components, Wrenching
    Last Post: 03-20-2004, 12:24 PM
