Older style Campy Centaur Ergopower Left Shifter with Compact Chainset
Results 1 to 5 of 5
    Mar 2020
    Hi Folks,
    New here so bear with me please
    I picked up a used 2005 Cervelo Soloist Centaur with a compact chainset (2 rings). The left shifter feels like it has 5 clicks for indexed shifting so it becomes incredibly cumbersome to shift the front during a ride as to move up it takes 4/5 shifts and then the chain starts to rub so i have to pull it back a bit.
    Is there anyway to tune this properly?
    Thank you in advance.
    Tino
    Reputation: nova_rider's Avatar
    Sep 2005
    Check the limits and positioning on the FD and make sure it has about 1mm gap between the chain and the cage plate on the lowest gear and about 2 mm between the tip of the large chainring teeth and the outer cage plate. When adjusted properly, the FD should shift to the large chainring on the third click.
    Mar 2020
    Quote Originally Posted by nova_rider View Post
    Hey, thanks nova.
    So for the 1mm gap, you mean the chain and the back of the cage correct and not the bottom of the cage?
    Sep 2005
    Quote Originally Posted by tinof View Post
    Hey, thanks nova.
    Correct, just try to get as close as you can without the chain rubbing.
    Matnlely Dregaend
    Reputation: DrSmile's Avatar
    Jul 2006
    I have this setup with a 48/34 crank and honestly it shifts fantastic. 3 clicks you're in the big ring and the release to the small ring is two clicks - one for trim for the big ring and one for full return.. Now if only the rear did thumb lever multishift like 09 Centaur...
    “Bicycling has done more to emancipate women than anything else in the world.” - Susan B. Anthony 1896
    "Cycling and ethical bankruptcy have always gone together." - Bike Snob NYC
    "White personifies this generation's obsession with superficiality, one in which a carefully curated social media post is more important than the actual ride" - Daimeon Shanks
    "I haven't been %^&* like that since I was an altar boy" Hank Moody
  1. Replies: 9
    Last Post: 04-03-2020, 02:33 PM
  2. Replies: 5
    Last Post: 04-22-2014, 07:34 PM
  3. New style 10sp Centaur levers on Old style 10sp?
    By Hillen in forum Campagnolo
    Last Post: 03-05-2011, 06:39 PM
  4. Centaur Ergopower or Ergopower Ultra Shifters
    By pulser955 in forum Campagnolo
    Last Post: 06-07-2010, 11:22 AM
  5. Replies: 3
    Last Post: 03-25-2010, 10:18 PM
