Seat Post Question
Results 1 to 3 of 3
    Nov 2014
    Seat Post Question
    I have an early 2000s Chorus Seat Post. This is the "flattened" top section version, SP-10CH.
    Having trouble finding the instructions/documentation from Campy and I am fitting a new saddle and wanted the seat rail clamp torque recommendations.
    Then I found a technical manual from 2011 with a carbon seat post but with the same metal hardware at the top. These instructions called for a minimum seat rail clamp torque of 18Nm with a max of 22Nm. Also eye-opening was a warning to "never lubricate the fixing screw".
    Your thoughts?
    Reputation: nova_rider's Avatar
    Sep 2005
    What is your main concern, the saddle or the seatpost? As long as you are not using any non-metal rails, these values should be fine. But I would slowly ramp up and check as you go. I had a 2004 Record seatpost and never checked the torque. It was a big bolt and I don't think one can overtighten with a typical length hex key.
    Sent from my moto x4 using Tapatalk
    Nov 2014
    I always just snugged it up with a 6mm hex key (the longer variety. Now though, I was replacing the saddle and thought it would be good to consider the torque requirements. I was surprised to see the 18Nm min and 22Nm max (that's pretty high) as well as I never saw a warning not to lubricate the clamp screw.
  1. Replies: 1
    Last Post: 07-18-2010, 02:48 PM
  2. seat post question (x-post from retro forum)
    By seeborough in forum Fixed/Single Speed
    Last Post: 12-03-2007, 03:46 AM
  3. How much seat post extended is too much seat post
    By climbin'junkie in forum Components, Wrenching
    Last Post: 05-31-2006, 03:53 AM
  4. How much seat post in the seat tube is enough?
    By Vinokourov in forum Components, Wrenching
    Last Post: 10-11-2005, 12:36 PM
  5. Cordura seat bags and carbon seat post (potential) issue
    By Lt. in forum General Cycling Discussion
    Last Post: 08-06-2005, 12:18 PM
