What's the largest campy 10-speed cassette that i can use?
Results 1 to 16 of 16
    What's the largest campy 10-speed cassette that i can use with a regular sized rear derailleur and a regular 39-53 crank set?
    Feb 2002
    It depends
    Quote Originally Posted by Speed_Metal View Post
    A standard derailleur will handle the 29t largest cog with no problem, but it most likely would not have enough capacity to keep the chain under tension with a 39/12 or maybe a 39/13. If you never go into those combinations, then you can stick with a standard cage. For example most people who would need a 29t cog would get a 13-29 cassette, and so the 39/13 would be "off limits" due to cross chaining. If you want to be able to use the 39 with smaller cogs then you need a longer cage RD.
    Jan 2010
    Just use my rule. 30t total takeup is max with the std RD.
    So, a 53/39 front it taking up 14 of those. Leaving 16 to go.
    If you use a 29T large cog then 29 - 16 = 13.
    So a 29 x 13 cassette will work.
    All this also implies that the chain length has to be just right also.
    There's sometimes a buggy.
    One.
    Reputation: David Loving's Avatar
    Jun 2008
    You can use a small rear der with a 13-29 if you don't cross chain. I'd use at least a medium though (I do).
    Waxahachie, Texas
    Biciclette Gios
    "Forget it, Jake. It's Chinatown."
    Reputation: soup67's Avatar
    Quote Originally Posted by David Loving View Post
    Can the cage be swapped out without replacing the whole derailleur?
    Nov 2009
    Quote Originally Posted by soup67 View Post
    The spare parts catalog indicates that the long cage cannot be used on the short and medium derailleurs but omits any mention of conflicts between those which suggests that a short <-> medium interchange is officially supported.
    Note however that prior to the current redesign Record and usually Chorus rear derailleurs affixed the cage with a bolt whilst lower level offerings sometimes had a stud on the cage which was retained via a clip.
    Also note that at least some of the parts affixing the non-body end of the B-tension spring have at least two positions for more and less tension so changing cages may suggest an adjustment there.
    Jun 2008
    Report back on how it went if you try it, please
    Waxahachie, Texas
    Biciclette Gios
    Jan 2010
    You don't need to change the cage. Just get the chain length right. It should look something like this:
    One.
    I am trying to make this work on my wife's 2006 10sp Chorus Compact. I think I need a longer cage. Sounds like the medium should bolt on?
    Nov 2013
    What's the largest campy 10-speed cassette that i can use with a regular sizedrear derailleurand a regular 34-50 crank set?
    I have a centaur 10sp from2008, and would like to use a 29-13. Is this possible?
    Jan 2010
    My pictures above were of a 50-34 crank.
    There is a 2-part answer to your question.
    If you want to be able to use both the big-big and small-small combinations (not that either is advisable), then my 31T max rule for a short cage RD applies.
    So, since 16T are used in the chainrings, 15T is left for the cassette. If you start with a 29T big cog then (29-15) a 14T small cog is the smallest that can be used.
    The second part of the answer is that you can still use a 29-13 safely, it's just that the chain may go slack in the small-small combo. The picture above should help.
    I just fitted a friends bike with a 12-29 and 50-34 up front. He understands that he's not going to use the 12 and 13T cogs while in the small ring.
    As I said before, all of this ONLY WORKS if the chain length is right. It's useful to use a chain with a link, to make fitting to correct length easier. And in this case fit so that the big-big can be used safely without overextending the RD.
    One.
    Nov 2013
    Thanks for this, Julio!
    Jan 2010
    One thing I forgot to mention is to back out the "H" screw for maximum clearance of the upper jockey wheel from the 29T cog.
    Steps 12 and 13 here http://www.campagnolo.com/repository...derailleur.pdf
    One.
    Nov 2013
    Again, thanks for this. I just found a 30-12 cassette. Do you think it's too much for my CT crankset, standard cage?
    Jan 2010
    Quote Originally Posted by Walvis43 View Post
    It will work, now I'm thinking that my friend's might have been a 30T not 29.
    Size the chain to be safe in big-big, and realize that you won't be able to go small-small.
    One.
    Nov 2013
    Great, Thanks!
