Will a short cage 10 speed Chorus rear derailleur work okay with 12-27 and 50/34?
Results 1 to 6 of 6
    Oct 2018
    Question Will a short cage 10 speed Chorus rear derailleur work okay with 12-27 and 50/34?
    Will a short cage 10 speed pre-2010 Campagnolo Chorus rear derailleur work okay with a Centaur 12-27 cassette and compact 50/34 chain set without any drama? I try not to cross chain small-small or large-large, but don't want a disaster if that happens.
    I think Campagnolo say a max cog size of 26T, but that was before the 12-27 cassette was available. Chain wrap would be 31 teeth, which I think may be slightly over spec.
    Jun 2013
    Quote Originally Posted by Oxford_Guy View Post
    You are correct, the combination that you want to run does exceed the designed capacity of the derailleur with a frame and gera hanger that are compliant with the Campagnolo spec.
    You would need to run a chain 1 link longer than optimal to be safe in "big to big" bit this would mean inadequate tension in small-to-small, with the result that you would have a slack idler run on probably the smallest two sprockets (depends on frame geo how bad this is).
    Slacl chain on small to small is not in itself a disaster BUT - it can lead to quite a bit of lateral whip in the chain and an increased risk of the chain being caught on the back of the big ring and giving a chain-suck type effect which can be a bit disasterous for your paintwork (and in an extreme case can lead to a chain so thoroughly jammed that you end up bending a chainring and / or having to drop the crankset off to free the chain.
    The fact that Campagnolo launched 12-27 after the max sprocket and capacity information was released is largely irrelevent - these things are not governed by production, they are governed by a combination of frame geometry, exected chain tension, front and rear derailleur design / geometry.
    At one time, Campagnolo made a compact crankset with a 48 outer in 10s, for instance, which could be used with a 12-27 cassette if a compromise was made in the setting of the "H" screw, or on bikes with a rear derailleur hanger at the upper end of the hanger length specification. That could actually be worked around by changing the H screw drive ratchet for a longer one from the 11s component range ... it all depends what compromises a user is willing to make on function and how much modification a mechanic is competent to make and in new material, whether warranty is an issue that matters to the end user.
    HTH
    Graeme
    Velotech Cycling Ltd
    Nationally recognised & accredited training for cycle mechanics
    Main Campagnolo SC UK
    NB - Please don't PM me here, please email to velotechcycling"at" aim"dot"com
    Oct 2018
    Okay, shame, that sounds like "not really recommended", due to the issues you mentioned. I can run a Medium cage Veloce RD, but the Chorus would've been nicer. Looks like you can still get 10 speed Record RDs, but expensive and too much carbon really for the build I have in mind
    Can you get an alloy medium cage conversion kit for the Chorus RD?
    Oct 2018
    BTW with a medium cage 10-speed Veloce (most recent generation - RD11-VLXM) or Record (older - RD4-REXM) derailleur would it actually even be possible to run a 12-30 Centaur cassette with a compact chain set? Don't think I need that for regular use, but could be useful for trips to the mountains (or Yorkshire...).
    May 2007
    Since it is only one tooth beyond the limit you should be good with the right chain length. I may be wrong but you also have to research the capability of some of the lower end rear derailleurs with the higher end shifters and capacity. There have been generations where the tech won't let you run them all together. I am sure someone will correct me if I am wrong.
    Oct 2018
    Quote Originally Posted by Bee-an-key View Post
    Shifters will be 2006-era Veloce or Record (so Ultrashift, effectively) 10 speed.
  1. Rear Derailleur: Short cage or medium cage?
    By Wood Devil in forum Components, Wrenching
    Last Post: 11-07-2017, 11:38 AM
  2. Ultegra Di2 11 speed Rear Derailleur (short cage)
    By 202cycle in forum Classifieds
    Last Post: 03-23-2017, 03:12 AM
  3. Sram Red Rear Derailleur Aero Glide short cage vs medium cage?
    By ZachUA in forum Components, Wrenching
    Last Post: 02-10-2014, 11:33 AM
  4. Rear derailleur short cage vs. long cage???
    By Roubaix29 in forum Components, Wrenching
    Last Post: 07-28-2010, 09:56 AM
  5. short cage to medium cage Chorus
    By Jdub in forum Components, Wrenching
    Last Post: 08-07-2004, 06:08 AM
