2018 CAAD12 widest tyre?
Results 1 to 9 of 9
    Sep 2007
    Is 28C the widest tyre that will fit on a 2018 CAAD12?
    I'm looking to change the wheels to something with a 21mm internal width and was hoping that a 28C tyre would fit, if not a 30 or 32.
    JSR
    JSR is online now
    Feb 2006
    I rode with someone on a CAAD12 today, running 28s. I think he could have handled 30s. It was suggested 32 might fit, but it would be tight!
    Jan 2018
    I had schwalbe ones 28mm on my rim brake caad12 . Wouldn’t have fitted anything wider. They are a wide enough tyre prob about 29mm in reality though . Anything wider would have rubbed
    Sep 2007
    Thanks. I'll see how a 28C fits.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Don't think 28mm tires will fit with 21mm rims. It will be a very tight fit if they do. Your tires will probably rub your chain stays on climbs unless your spoke count is at least 28, preferably 32. A low spoke count wheel will flex more on climbs and definitely rub.
    I have a 2014 Cannondale Synapse Carbon with 28mm tires and 18mm rims. The chain stay clearance is only about 3mm on each side. I run a 32 spoke rear wheel. When I ran a lower spoke count wheel, I had rubbing on climbs.
    I believe the CAAD bikes have less clearance than the Synapses.
    "With
    -- DCGriz, RBR.
    Reputation: whostolemyname?'s Avatar
    Sep 2015
    Do you have this rubbing with the 28mm tyres?
    Asking because I'm trying to figure out the widest tyres I'll fit on my 2014 synapse carbon (running Shimano RS11 wheels) - sorry for the thread-jack!
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by whostolemyname? View Post
    The Shimano RS11 wheels have a very low spoke count - 16 front/20 rear. Those came stock on my Synapse and yes, I got some rub on climbs with the 28mm tires. When I built up wheels with a higher rear wheel spoke count, that went away.
    Lower spoke count wheels will flex more. There is no way around that.
    "With
    -- DCGriz, RBR.
    Sep 2015
    Thanks very much. Sounds like I should stick with 25s.
    Pity, I am contemplating a gravel event and was thinking of running the synapse with some meatier rubber.
    Banned Sock Puppet
    May 2014
    Or get higher spoke count wheels.
    "With
    -- DCGriz, RBR.
  1. RBR TdF 2018 Predictions! Post by Start Time 2018
    By PJay in forum Pro Cycling - Tour de France
    Last Post: 07-28-2018, 07:45 AM
  2. Any caad12 owners out there yet?
    By bjb85runner in forum Cannondale
    Last Post: 10-10-2015, 12:23 PM
  3. CAAD12 frameset cost
    By filly in forum Cannondale
    Last Post: 10-10-2015, 12:17 PM
  4. CAAD12 release date and pricing?
    By gti5notrkt in forum Bikes, Frames and Forks
    Last Post: 07-25-2015, 06:08 PM
  5. Nation's #1 Beast on a CAAD12?
    By MMsRepBike in forum Cannondale
    Last Post: 06-29-2015, 10:11 AM
