Short Cyclist on XS frame (48cm) so shorter cranks?
Results 1 to 9 of 9
    Jan 2014
    I'm helping a coworker source and build her next bike... She's short... 5' tall and I can't help but think that there has to be some advantage to someone this short going to short cranks? Not just 170's but perhaps even 165s. She literally looks a bit awkward on the 172's she has now.
    Is there some train of thought around this? I have 172.5 on most of my bikes an 170's on a travelling bike that I do a lot of climbing with. I can't honestly say I notice a massive difference (If any)... Perhaps my Strava data would show something different... But not about me... About her...
    Thoughts? I'm sure a professional bike fit will get her pointed in the right direction but just looking to see what thoughts might be.
    2015 Guru Photon R Disc Custom - Super Record (15 lbs)
    2016 Olympia Boost Dura Ace Di2 (14.5 lbs)
    2019 Cannondale Synapse, Ultegra Di2 - Mavic Cosmic Carbons
    2016 Storck Aero Road Build - SRAM Red
    2006 Colnago Strada Scandium Record Group FSA cockpit/brakes and Mad Fibers (14 lbs)
    Road Team Sponsor and M3 Racer (Team Techykids.ca)
    Fav accessories:
    Mad Fibers, FSA Bars, Power2Max Power Meter Crankset(s), Mavic R-SYS SLR and Carbon Tubulars
    -Self admitted Weight Weenie!!!
    Reputation: krisdrum's Avatar
    Oct 2007
    165s are probably a better choice. I'm 5-6 and run 170s on my road/cross bike. Frankly could maybe go shorter, as I do like to spin. But I think a professional fitter with lots of experience would be a good option.
    There was a recent video series on YouTube with an Australian rider (I think 5-10 or more) getting a fitting and was suggested he go from 172.5 down to 165 in order to help rotate his pelvis lower and deal with some hip flexibility issues. So not sure there is a hard and fast rule.
    Sep 2011
    165mm is the longest she should ever use.
    if possible, she should go down to 160mm or even shorter, but unfortunately the bigs don't sell 160mm or shorter, but customizers do sell them for a price
    https://www.bigandtallbike.com/RoadC...anks_c_93.html
    May 2012
    IMV, definitely go for 165mm as a maximum. Not only will it suit leg length better, it will also help a bit with toe overlap which is always a problem with XS frames (although Canyon use 650 wheels on some of those). Shorter than 165 would probably be better but as aclinjury says price and availability are issues
    Sooper Dooper Moderator!
    Reputation: il sogno's Avatar
    Jul 2002
    I'm 5' 4" and on a 48 cm frame. I use 170mm cranks.
    Reputation: rudge66's Avatar
    Mar 2019
    Quote Originally Posted by il sogno View Post
    you're riding well if you can power ride your drop for a sustained period.
    Short cranks are the new market pitch. its just getting silly.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by rudge66 View Post
    The only thing silly here are your misleading posts. So you're saying that everybody regardless of size should use the same crank lengths?
    "With
    -- DCGriz, RBR.
    Mar 2019
    Hmmm.... did I say that?
    Focus Lombard, .. Bike Fit is not your forte.
    Nor are recommendations for $900 Claris bikes from Walmart
    Banned Sock Puppet
    May 2014
    Nor yours.
    Did I say anything about Walmart? I don't think so.
    "With
    -- DCGriz, RBR.
  1. Too Short for a 585 Optimum Elle XS
    By hawker12 in forum Look
    Last Post: 11-14-2013, 12:12 PM
  2. Replies: 20
    Last Post: 05-13-2013, 03:35 PM
  3. Chainrings and shorter cranks
    By ddayton217 in forum Components, Wrenching
    Last Post: 04-20-2012, 09:35 PM
  4. Longer top tube/shorter stem or shorter top tube longer stem
    By Ranger Pride in forum Beginner's Corner
    Last Post: 01-15-2011, 09:50 PM
  5. Shorter Cranks Anyone?
    By Dereck in forum General Cycling Discussion
    Last Post: 06-08-2006, 05:56 AM
