Cygolite DASH?
Results 1 to 4 of 4
Thread: Cygolite DASH?
    Jun 2005
    Cygolite DASH?
    When I commute, especially in the spring and fall, sometimes I'm on the road for 15-30 min before the sun comes up. I'm in town for that time, so the roads are generally lit, but with a few dark patches. The whole commute is around 80 min. So I need a "see" light for around 15-30 min, and then it becomes a "be seen light" for another 30 min.
    I have a Cygolite Expilion 700, which I like for a lot of reasons. Bright, well built, good battery life, rechargeable. I originally bought it to put on my helmet, but it just got uncomfortable, so I switched it to my handlebars.
    The biggest gripe I have with it is that on bumps, it rotates down and faces the ground, so I have to readjust it a few times every ride.
    I'm thinking about the Cygolite Dash 520. I know this isn't as bright, but it has a strap mount, and it's shorter and lighter, so I'm hoping it will stay in place better. They also make the Dash Pro 600 which has the advantage of being brighter, but it's longer, so I'm afraid it will tilt down as well.
    Does anyone have any experience with either of these lights?
    Thank you!
    Oct 2017
    I don't commute much these days, but I do keep a Cygolite Dash on my handlebars for rides that start early or end late.
    I have mine hanging under the bars rather than on top, and havn't noticed any problems with it rotating.
    It's a pretty light weight unit, but the bar strap is towards the back, so I suppose with rough roads or big bumps it might rotate down a bit, but I haven't noticed it being a problem for me.
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    Quote Originally Posted by TiCoyote View Post
    Thank you!
    I suggest checking the mounting of your Expilion light, if it's rotating enough to have to readjust so much. I have a couple of the Expilions, and I've found the mounting system to be rock-solid. I don't have experience with Cygolite's strap-mounted products, but it seems to me that a strap would be more prone to rotating down than mounts used on Expilions.
    Donald Trump has never had a wife he didn't cheat on.
    "Oh my god. This is terrible. This is the end of my presidency. Im fd.
    Reputation: velodog's Avatar
    Sep 2007
    Can you shim it a bit with a wrap of handlebar tape so the clamp is tighter? The tape should make a crush fit that may hold it tight enough so that it doesn't twist.
    Too old to ride plastic
  1. so I had a kitten wedged up under my dash board
    By nonsleepingjon in forum The Lounge
    Last Post: 12-15-2011, 06:25 PM
  2. Food for thought, with a dash of gun powder.
    By DrRoebuck in forum Politics Only
    Last Post: 01-23-2011, 01:48 AM
  3. Replies: 3
    Last Post: 12-24-2010, 09:19 PM
  4. Anybody sell an in-dash head unit?
    By Len J in forum The Lounge
    Last Post: 09-27-2010, 05:39 PM
  5. Has anyone ridden a Dash saddle?
    By PhotoNinja30D in forum Components, Wrenching
    Last Post: 05-11-2010, 08:49 AM
