10 Sp. rear derailleur w/9 sp system
Results 1 to 3 of 3
    Jun 2005
    Can I use a 10 sp Campy rear derailleur with a 9 sp Campy system just by changing the pulleys to 9 sp? thanks!
    It'll work just fine...
    ...without changing the pulley's.
    On a sub-atomic level, a pulley swap will improve shifting just enuf that a scanning electronic microscope might see a difference...
    PH
    yes, but...
    The shifting will not be perfect, not because of the pulleys, but due to a change that Campy made to the RD's parallelogram.
    http://www.campagnolo.com/qea_search...cid=1&key=comp
