105 5700 shifters vs. RD-6600 GS and FD-5600
Results 1 to 3 of 3
    Reputation: laperted's Avatar
    Jul 2009
    In my upgrade process I'm considering replacing the 105 shifters with modern 5700s. As the Shimano compability webpage is off line, here are my questions:
    1) Will 5700 shifters work properly with a 6600 GS rear derailleur?
    2) Will 5700 shifters work properly with a 5600 front derailleur? And...
    3) The original brakes are Shimano, but I don't think they're 105s; so do I need to replace them too?
    Thanks in advance.
    Los Barriles, BCS, Mexico
    Reputation: DaveT's Avatar
    Yes to questions 1 and 2, no issues. You won't need to replace your brakes.
    Trying to cram the rest of my life into the rest of my life!
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    No problems here.
    It was the 5800/6800/9000 generation that Shimano changed the shifting cable pull ratios. 5600/6600/7800 shifting components play fine with 5700/6700/7900.
    As far as braking, cable pull ratios changed between 5600/6600/7800 and 5700/6700/7900. However, the way you are going - 5700/6700/7900 shifters with 5600/6600/7800 brake calipers will work. The other way around will be too spongy.
    "With
    -- DCGriz, RBR.
  1. Shimano CS-5600 vs CS-5700
    By mfm in forum Components, Wrenching
    Last Post: 12-05-2013, 12:15 PM
  2. Shimano RD-5600 v. RD-5700
    By Stogaguy in forum Components, Wrenching
    Last Post: 06-21-2012, 12:23 AM
  3. 5600 to 5700 and chain noise????
    By nspilka in forum Components, Wrenching
    Last Post: 01-17-2012, 04:57 PM
  4. Is a 5600 105 FD compatible with 5700 levers?
    By minutemaidman in forum Components, Wrenching
    Last Post: 04-29-2011, 07:25 PM
  5. Price of Shimano 105 old 5600 vs new 5700
    By grs1969 in forum Components, Wrenching
    Last Post: 06-16-2010, 06:21 PM
