10sp 105 rear STI shift/brake missing...
Results 1 to 12 of 12
    Jan 2019
    It's 10 years old. When I attempt to go from big to small in the cluster the shifter misses. It takes sometimes 2/3 attempts to get it to drop in many gears.
    Ideas?
    'brifter' is f'ing stupid
    Very common w/ all types of Shimano shifters. The grease that was used when it was originally built is getting sticky. Spray inside the shifter w/ WD40 or a spray solvent or spray lube then shift the crap out of it. If you direct the spray where the cable is installed you should be fine. They nearly never break, they just get sticky.
    Whatever you do don't attempt to take it apart in any way.
    #promechaniclife
    Some sort of friction not allowing enough cable to release, probably.
    Could be a frayed cable inside the shifter so get on it soon because that can suck if it goes to far.
    Jan 2019
    Thanks!
    Jan 2019
    [QUOTE=cxwrench;5388555]Very common w/ all types of Shimano shifters. The grease that was used when it was originally built is getting sticky. Spray inside the shifter w/ WD40 or a spray solvent or spray lube then shift the crap out of it. If you direct the spray where the cable is installed you should be fine. They nearly never break, they just get sticky.
    I know about not taking it apart. I would not be able to get humpty back together!
    Thanks!
    If the shifter 'misses' as the OP says it's most likely not a frayed cable. If the paddle or the lever moves but there's nothing happening it's stuck/sticky. If you can feel the paddle and/or lever being more or less normal but the shifting is off in one direction or another right away then that's a frayed cable. Very different feel. Obviously you can undo the cable at the derailleur and push it out of the shifter and look as well.
    #promechaniclife
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    It's probably the thing cxwrench suggests, I've experienced that one myself with old 6600 or 7800 shifters (I forget which).
    Jan 2019
    NVM, thanks.
    .je
    .je is offline
    Reputation: .je's Avatar
    Aug 2012
    Is it like this?
    https://forums.roadbikereview.com/co...ft-314443.html
    Mine did that when it was about 10 hours old. It still does this but not as much. It is worst in cold weather such as below freezing.
    Lubing with Prolink or something like that improves it for a few months.
    Jan 2019
    It is only when I am going from bigger to smaller cogs in the back. I am going to hit it with WD40 tomorrow. I think it should fix it.
    Jan 2019
    The WD40 worked like a charm.
    Quote Originally Posted by Scottay5150 View Post
    You're welcome.
    #promechaniclife
  1. Replies: 23
    Last Post: 05-14-2014, 04:36 PM
  2. Right Shift Lever won't shift (105)
    By hamsandwich in forum Components, Wrenching
    Last Post: 07-27-2012, 07:30 AM
  3. Shift cable stuck in SRAM Rival shift/brake lever
    By outhere in forum Components, Wrenching
    Last Post: 01-29-2012, 05:44 PM
  4. Will a 10sp 105 Cassette fit an 8sp 105 hub?
    By milroy in forum Components, Wrenching
    Last Post: 02-15-2006, 03:45 PM
  5. shimano sti 105 brake lever rear problem
    By ggusta in forum Components, Wrenching
    Last Post: 08-11-2005, 06:08 PM
