13 mm cone wrench or 13/14 or 13/15 combo?
Results 1 to 9 of 9
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    I know this is a silly thing to noodle over, but...
    I need a 13 mm cone wrench for one reason, which is to install/adjust SRAM Red 22 brakes on a build I am doing.
    I'm trying to decide between a single 13 mm cone wrench or a double ended 13/14. Is there anything in the world I'd need the 14 for? I am not ever going to mess with Campy hub cones...
    In the middle of writing this post I see there are also 13/15 combos...
    Reviews for the Park combo wrenches have remarks about them being soft and bendy.
    Any suggestions? Regular adjustable wrenches I have, even the small ones, are too thick for the particular job.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Murphy's Law says shortly after you buy that single size wrench you're going to find a need for the combo wrench. Whether your bike, a friends bike or something non-bike around the house.
    Neophyte
    Jul 2007
    Right? That being the case, what would be more useful, 13/14 or 13/15?
    But I really like the idea of the seemingly higher quality of the single.
    tlg
    tlg is offline
    May 2011
    Quote Originally Posted by jetdog9 View Post
    Whichever one you pick will be the wrong one so pick the other one.
    Sep 2011
    13/15. You'll rarely need a 14mm cone wrench.
    Nov 2014
    Because I often find a need for more than one at a time, I use both, the 13/14 and 13/15.
    Feb 2002
    Impossible to predict since we don't know what components you have or will have in the future. I suggest getting a 13/14 and a 15/16 or 15/17. You really can't have too many tools.
    Neophyte
    Jul 2007
    I ended up ordering the 4-piece Park set (DCW-1, 2, 3, 4) which gives me in total 13/14, 15/16, 17/18, 13/15.
    I pretty much never mess with hubs, although I have 2 Shimano wheelsets so I guess it's good to have these in case.
    I know they say cheap tools are just more expensive later, but I honestly don't see using these often enough to wear them out like shop mechanics seem to.
    Edit: Of course the White Industries Eccentric ENO hub on my Singlespeed takes a 19mm wrench, but the space is wide enough to take a regular wrench.
    Sep 2005
    jetdog-
    You won't regret the purchase. Plenty tough for the home workshop.
  1. Replies: 4
    Last Post: 07-26-2011, 08:24 PM
  2. Quality 15 mm axle nut wrench, 4 3/4" long.
    By wim in forum Fixed/Single Speed
    Last Post: 11-25-2009, 12:34 AM
  3. Pedal cone wrench
    By DIRT BOY in forum Components, Wrenching
    Last Post: 06-01-2009, 12:37 PM
  4. 14 gauge instead of 14/15
    By dagger in forum Wheels and Tires
    Last Post: 08-24-2007, 06:27 PM
  5. Cone wrench size for Campy Mirage?
    By bw77 in forum Components, Wrenching
    Last Post: 08-24-2006, 07:27 AM
