130mm rear wheel spacing- What hubs/cogs?
Results 1 to 5 of 5
    Climbin' Clyde
    Reputation: Sablotny's Avatar
    Aug 2002
    I just scored an 88 Pinarello Treviso 'cross frame on Ebay as a commuter project. It has 130mm rear dropout spacing, and I'm assuming 100mm at the fork. If I use Shimano bits, what am I looking for in hubs & cassettes- 7/8 speed with 130 MTB hubs? Thanks for any advice; any more info on the Pinarello would be welcome too. All I know is that I like the lugged steel and lime green paint.
    Apr 2000
    MTB hubs (at least anything within the last 15+ years) are 135mm; with 130 spacing, you can use any 7/8/9/10sp road hub, and any (road/MTB) cassette you like. There's no reason a good (105 or above) road hub can't stand up to use on a 'cross bike.
    Reputation: Trevor Ash's Avatar
    May 2005
    Although I can't speak form personal experience, it's my understnading that you can remove the bearing covers on some hubs (like surly track hubs) so that a 135 will fit in a 130. Like I said, never done it...but something to look into possibly.
    Reputation: Nessism's Avatar
    Quote Originally Posted by The Walrus
    Most Shimano 7 speed road stuff is 126mm rear spacing. It's fairly easy to space it out to 130 though with a longer axle and a few spacers. 8/9/10 speed road is all 130mm.
    Apr 2000
    Oops! My bad--you're absolutely right. Must've been over-caffeinated when I was typing my response.
  1. creeking in rear wheel..
    By bahueh in forum Wheels and Tires
    Last Post: 07-25-2005, 08:22 AM
  2. Replies: 0
    Last Post: 07-06-2005, 12:12 PM
  3. How effective is the rear aero wheel?
    By NoMSG in forum Bikes, Frames and Forks
    Last Post: 01-23-2005, 08:47 PM
  4. Does 1 lb of fat = 1 lb of frame?
    By Bacco in forum General Cycling Discussion
    Last Post: 08-03-2004, 09:21 PM
  5. Can Shimano wireless Flight Deck be used with rear wheel?
    By Larry Klassen in forum Components, Wrenching
    Last Post: 07-04-2004, 09:07 AM
