Results 1 to 4 of 4
    Reputation: smokva's Avatar
    Jul 2004
    26T front derailleur capacity
    I'm building triple touring bike and have Shimano 105 FC-5703 50/39/30 crankset.
    For it to pair I have FD-4603 front derailleur.
    I also have 53T-B spare chainring that I plan to use instead of 50T one. For this 53/39/30 combo I have Ultegra FD-6703...thid fd will not shift properly 50/39 combo so I'm not using it with 50T big ring.
    Since I plan to do a lot of loaded climbing on my touring, what I want to do now is install 24T small ring. I plan to use it in 50/39/24 combo meaning I need derailleur with 26T capacity.
    Officially FD-4603 has capacity of 20T, but has anyone tried it and will it work in 26T big-small difference mode?
    Ultegra FD-6703 has officially 22T capacity, but for it with small 24T I would have to use 53/39/24 combination giving 29 differance. Did anyone try FD-6503 successfully in this setup?
    Sent from my SM-G925F using Tapatalk
    Ante Smokrovic
    2009 De Rosa Neo Pro - Fedaia, Giau, Pordoi, Sella, Gardena, Campalongo, Falzarego, Valparola, San Pellegrino, Valles, Staulanza, Vršič, Mangart, Furcia...
    2003 De Rosa Team - Stelvio, Gavia, Mortirolo, Bonette, Agnel, Izoard, Fedaia, Giau, Pordoi, San Pellegrino, Staulanza, Manghen, Vršič, Učka, Mangart, Biokovo, Eisentalhöhe, Schonfeld, Schiestelscharte, Flattnitz...
    Reputation: Lombard's Avatar
    May 2014
    I doubt this would work very well if it works at all.
    If you really want a triple with low gearing, you will need to find an older mountain or touring crankset. Check eBay for new/old stock.
    Out riding.
    Reputation: 1500SLR's Avatar
    Sep 2018
    You're gonna struggle with this. You're going to need a combination of road/mountain crankset/groupset to find a combination that is going to make this work.
    Jul 2004
    In meantime i installed what I wanted.
    Shimano 105 FC-5705 50/39/26 crankset. Instead of stock small 30T I put Stronglight 26T.
    Derailleur is Tiagra FC-4603.
    Thing works perfect, without single problem, shifts are without any hesitation.
    Cage is low enough for 26T, however I think it's the lowest possible, with 24T chain would rub on the cage.
    With Ultegra triple front derailleur which is designed for 52T big I'm sure I would get 53/39/26 to work.
    Ante Smokrovic
  1. Shimano 105 Front Derailleur Capacity?
    By rdtompki in forum Components, Wrenching
    Last Post: 02-10-2009, 02:55 AM
  2. Determining front derailleur capacity?
    By PseuZQ in forum Components, Wrenching
    Last Post: 08-25-2007, 07:07 PM
  3. Campy front derailleur capacity w/ compact?
    By hdnoise in forum Components, Wrenching
    Last Post: 12-19-2005, 02:44 AM
  4. Related gearing question...26t max?
    By brewster in forum Campagnolo
    Last Post: 05-19-2005, 04:37 PM
  5. Replies: 4
    Last Post: 03-17-2004, 04:43 AM
