28 tubes
Results 1 to 18 of 18
Thread: 28 tubes
    Oct 2013
    28 tubes
    How is the luck with running a 20-25 tube in a 28 tire?
    ... also what is the deal with all the removable valve stems, almost no standard stems available. I'm progressing to a threaded co2 inflator, the dam removable stem comes out when you unthread it.
    Is there a shortage due to the cov19?
    BANNED
    'brifter' is f'ing stupid
    They'll work. Tighten the valve up, my Lezyne pump unscrews maybe 1 valve a year.
    #promechaniclife
    Oct 2013
    ... so 25 tubes are ok in a 28?
    BANNED
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    If you don't need them removable, put a dab of glue or loctite on them.
    Yea no problem. Ever blow up a tube outside of the tire? It easily grows 1/8".
    It's 3mm...seriously, you don't think it'll handle stretching 3mm?
    #promechaniclife
    Feb 2002
    It's terrible when the dam breaks. Big flood for those living downstream.
    I use 23mm tubes in 33mm tires. 25 in 28 is a total non issue.
    Oct 2013
    ... it does stretch the rubber a little more. First tube purchase in years... I was a little concerned, a little, nothing wrong with checking with the experts!
    Well when your on the side of the road and the removable stem comes out, and you don't have pliers, and you don't have another tube, yes it is a dam brake! woops!
    BANNED
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    It grows WAY more than 1/8". Once just for shytes and giggles, I pumped up a tube until it popped. The diameter of that thing was at least 4 inches before it popped.
    Think of it as a budget light weight tube.
    "With
    -- DCGriz, RBR.
    Sep 2005
    Agree using slightly undersized tube is no problem.
    OTOH- Using an oversized tube is just a sh%t waiting to happen.
    tlg
    tlg is offline
    May 2011
    Like this
    Oct 2013
    OK guys, give it up.
    The smaller tube can be blown up, but the walls of the tube get thinner and the stress goes higher too!
    Ever pop a balloon with a pin, doesn't take much pressure. Try popping the balloon when it only has about 1/12 that full size. Hopefully your pea brains will figure out the just of my question.
    Now that guy has a big wheel!
    BANNED
    Ever pop a balloon with a pin, doesn't take much pressure. Try popping the balloon when it only has about 1/12 that full size. Hopefully your pea brains will figure out the gist of my question.
    Well when you're on the side of the road and the removable stem comes out, and you don't have pliers, and you don't have another tube, yes it is a dam brake! woops!
    ftfy...
    #promechaniclife
    Feb 2002
    At MOST you would experience slightly faster pressure loss because the tube is nominally 12% thinner compared to a 25. And just so you don't go extrapolating incorrectly, that does NOT mean 12% faster air loss. And even if it did, in my case that would mean a loss of about 8 psi per week instead of the about 7 psi per week loss I experience now.
    Reputation: ogre's Avatar
    Dec 2005
    I guess you’re not aware that 48ers are the next big thing with MTBers.
    Banned Sock Puppet
    May 2014
    Like this
    Yep! It was fun picking up pieces of butyl rubber all over my livingroom. A $7 cheap thrill.
    Pea brains? That's pretty harsh for a flawed analogy, don't you think? The balloon analogy is hardly valid for blowing up a tube in a 28mm tire that is rated for a 20-25mm tire. As I said before, what do you think a "lightweight" tube is?
    "With
    -- DCGriz, RBR.
    okay, that's settled. Not sure why someone with all the answers already would ask a bunch of pea brains for an answer but whatever.
    Banned Sock Puppet
    May 2014
    You must spread some Reputation around before giving it to Jay Strongbow again.
    "With
    -- DCGriz, RBR.
  1. Tubes, Tubes, Tubes, there is a difference
    By Mr645 in forum Wheels and Tires
    Last Post: 10-06-2014, 08:26 PM
  2. Tube Question: what does 20/28 and 28/38 mean?
    By cjo in forum Wheels and Tires
    Last Post: 03-16-2009, 05:26 PM
  3. Tunnel closure for 8/28-9/28
    By hdnoise in forum Northern California
    Last Post: 08-24-2007, 10:03 PM
  4. Nice light clincher rims for retro project 28/28
    By DannyBoy in forum Retro-Classic
    Last Post: 04-24-2007, 06:19 AM
  5. Looking for 28/28 10 speed Campy Record Hubset
    By DannyBoy in forum Components, Wrenching
    Last Post: 03-31-2007, 05:00 AM
