4403 derailuir broken on trek sl aplha? What detailuir to replace it?
Results 1 to 11 of 11
    Mar 2019
    I have a trek sl aplha and the front derailuir is broken. Part number 4403. The seat tube is. 34.5. The 4403 is non brased.it has a removable collar.Please help . I am good got call Shimano tomorrow but I would like the forums help.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    If it has a removable collar, it's a braze on. Just order another derailleur.
    Sent from my SM-G930V using Tapatalk
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Mar 2019
    fd 4403 isn't avaible.Im calling shimano today and I hope they can help
    Rub it............
    Nov 2007
    Your LBS should be able to tell you if Shimano has them in stock vs. the parts distributor they use. Because some Shimano stuff has to be ordered directly from Shimano.
    Sep 2011
    Is this the same bike as the last broken front derailleur thread?
    Sep 2011
    Do you have a way to post a picture of your broken derailleur? Cause, that would be helpful.
    Mar 2019
    I called Shimano and the tech said they do not make a direct replacement for the 4403 derailuir on the stock 52 t crank. I am going to have to upgrade the crank to a 50t and I have options. I am low on cash and the crank is good enufe to commute. I took off the derailuir and set the chain on the middle crank set.when I get some money I will drop it off at the bike shop so they can take it from there.thats it! The 52 t is th problem why they donít make a direct replacement because how the industry has evolved. PeAce thanks for your help.
    Sep 2011
    Quote Originally Posted by s10aromeo View Post
    Get a 34.9 braze-on clamp and the Microshift FD-R539 braze on derailleur. That is your least expensive, most reliable option. When you start swapping cranks, bottom bracket, and derailleur, youíre just opening a can of worms. If Iím not mistaken, the cable pull on the new 50t compatible derailleurs is different than the shifter on your bike. If you have your part numbers right now, then trust me, this is the best option. If you want to chat more, PM me, Iíve done this repair twenty times in the last two years.
    Mar 2019
    I ordered the fd r539 brazed on. Will that derailuir fit my 4403 collar? I amuse the collar to derailuir is a universal fit. Thanks for your help !!
    Sep 2011
    It should work just fine.
    Mar 2019
    I got the 539 in today and it worked perfect after adjustments .thanks everyone for the quick response
  1. Trek 6000 broken chain=broken gears?
    By Johnstrek6000 in forum Trek
    Last Post: 08-01-2012, 08:26 AM
  2. Replies: 4
    Last Post: 08-08-2011, 10:18 PM
  3. Replace whole rear mech or just replace cracked inner cage?
    By miurasv in forum Components, Wrenching
    Last Post: 04-01-2011, 04:12 AM
  4. Do I need to replace the chain if I replace the cassette?
    By EDG in forum Components, Wrenching
    Last Post: 10-08-2009, 09:16 AM
  5. I crashed. Replace shifter or replace group?
    By bikersteve in forum Components, Wrenching
    Last Post: 05-29-2008, 07:03 PM
