• 02-05-2012
    Dgunn
    9 speed campagnolo centaur groupset with 8 speed shimano cassette
    hey there i have a 2001 9 speed campagnolo centaur complete groupset i was hoping to install but i only have a shimano wheelset and 8 speed cassette...i can get a 9 speed cassette but will this set up even work? and if it dose can i just use the 8 speed cassette i have already? thanks!
  • 02-05-2012
    Kontact
    The 9 speed cassette will work better, neither will work great. You can get a Jtek Shiftmate, or a new freehub body depending on your hubs.
  • 02-05-2012
    Touch0Gray
    there is a campy spaced, shimano hub compatible cassette available (at least in 10 speed)
    Evolution / Campagnolo compatible
  • 02-05-2012
    Touch0Gray
    hey.....I know nothing at all about shimano cassettes, but are they individual loose cog? If they are could you just use the campy 9 speed spacers between them? I probably have an extra set or two or three if that would work.
  • 02-05-2012
    Kontact
    Quote:
    I think the answer is "no" to both your posts. Campy cog thickness is different than Shimano's so swapping spacers only isn't going to produce the right spacing. And there doesn't appear to be 9 speed adapter cassettes available (any more).
  • 02-05-2012
    Touch0Gray
    Thanks......like i say i know zip about Shimano...I am all campy all the time (well my mtn bike has Shimano (but I haven't a clue what model) some 6 speed bio pace thing)
  • 02-05-2012
    Kontact
    Quote:
    Originally Posted by kaiter View Post
    You can get a Jtek Shiftmate, or a new freehub body depending on your hubs. http://www.lzxin.info/g.php
    Are you kidding me?
  • 02-05-2012
    onespeedbiker
    If you want 9 speeds go with Jtec. If you want to stay with 8 speeds buy a Shimano derailleur and use the hubbub derailleur routing Rear Shifting. The compatibility depends alot of how much cable different make (and sometimes model) pulls. However the derailleur is just a slave, so as long as it is Shimano 7, 8, 9 or 10(road) speed will work.
