Adhesive cable guides - rigid CX front fork for the disc brake cable
Results 1 to 4 of 4
    Sep 2008
    Where can I buy adhesive cable guides to go on a front carbon rigid fork (to attach the front disc brake cable w. zip-ties)?
    Also, separate question: when I tie the continuous cables to the CXframe with zip ties; how can I make these cable ends safe? Now they are like 12 separate little black knives. Do I cut them flush with a razor blade, or melt the end with a lighter or match?
    Idiot at large
    Apr 2010
    just zip tie it to the fork. you don't really need the extra expense of a cable guide.
    on my MTB... I never bothered with making the cut zip tie ends less sharp.
    2010 Specialized Secteur Elite with the RBR not-approved Mavic Ksyrium Elite wheelset
    2009 Specialized Rockhopper Comp 29er upgraded to SRAM X9 with 1x10 and Stan's Arch EX rims and tubeless.
    2013 Cannondale CAADX-6 Tiagra with 9-speed SLX RD to run 11-32T cassette and Stan's Alpha 400 rims and tubeless
    and
    Some Burton snowboard setups, one with stiff ol' Camber and one with Rocker-Camber-Rocker
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Use zip ties and position the cut ends towards the wheel.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Burnum Upus Quadricepus
    Reputation: brucew's Avatar
    Jun 2006
    I use these. No zip-tie.
    Jagwire C-Clip Housing/Hose Guide
    If you simply must have the ones that use zip-ties,
    Problem Solvers Stick-On Hydraulic Housing Guide
    Now that you know what to look for, you can search and find them all over the web. Or, you know what to ask your LBS to special order for you.
  1. Front brake cable hanger thingy mounted to fork
    By mdutcher in forum Cyclocross
    Last Post: 07-07-2012, 10:40 AM
  2. Front Brake Cable Routing
    By w98seeng in forum Components, Wrenching
    Last Post: 04-26-2011, 11:43 AM
  3. Can cable guides be used as cable stops?
    By Frith in forum Components, Wrenching
    Last Post: 12-13-2009, 11:48 AM
  4. Replies: 4
    Last Post: 03-02-2006, 03:58 AM
  5. brazing on cable guides and drilling brake bridge
    By ishmael in forum Bikes, Frames and Forks
    Last Post: 09-21-2004, 06:42 AM
