Adjusting Shimano 105 Rear Derailer
Results 1 to 5 of 5
    Reputation: TallCoolOne's Avatar
    Jan 2010
    I have been trying to learn how to adjust my rear derailer on my own through just enough internet reading and trial and error to be dangerous. I have everything running pretty smoothly shifting easily (maybe not bike shop tune up quality but pretty close I think). My only issue is that I get a little grinding when I am in the big chain ring and largest rear cog. I will never be in that gear combo so it a big deal? What can I do to get this gear combo to run smooth?
    2010 Cannondale CAAD9 5 63cm Charcoal Gray
    Crank Compact 50/34 Rear Cogs 12-27
    Handlebars Kore ROAD 6031
    Bar Wrap Profile Design Shock Wrap
    Pedals Speedplay Zero Cro Moly
    Seatpost Thomson Elite 410mm
    Computer/Cadence Sensor Garmin Forerunner 305
    Bottle Cages Specialized Rib Cage Pro Road
    Headlight ViewPoint Flare 5 LED
    Taillight ViewPoint Flashpoint Ultra
    "Hey, let's be careful out there."
    -Sergeant Phil Esterhaus
    Hill Street Blues
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Big gear up front and big gear in the back is considered cross chaining. Its a no-no. Most avoid this combo.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Dec 2009
    When the big-big combo is used it causes the chain to bend at such a angle that it is rubbing against the teeth of the cogsand chainring instead of gliding over the teeth. This rubbing grinds and helps to wear out the chain and cog/chainring faster than if the chain and gear selection was in a less stressful conbonation. The small/small gear combo is also frowned on (and usually noisier).
    Adventure Seeker
    Reputation: Peanya's Avatar
    Jun 2008
    Go to www.sheldonbrown.com and search gear ratios. You'll find out why there isn't any good reason to cross chain.
    I have a single track mind
    Reputation: Ventruck's Avatar
    Mar 2009
    Non-rubbing cross chaining is possible with the combination of proper RD and FD settings (noting that I have a 105 rear derailleur as well to get this working), but still ill-advised. Just make sure with both rings you can acesses about 6-7 sequential gears perfectly, one-by-one, both ways.
    A slight learning tidbit: Just because you paid for a 10 speed cassette, doesn't mean you're expected to make use all of 10 cassette gears per chainring. A 10 speed cassette does indeed have more range (gear selection) than a 9 speed cassette, but its true advantage lies within having closer ratios to reduce the differences when shifting through the rear gears - which in turn results in smoother transistions for changes in gradient (angle relative to the horizontal/flat). One could have the legs to muscle/spin a given gear if lacking the close-ness of such ratios, but it's not to say they're unable to benefit from then converting to a greater speed cassette.
