Aero Rim vs. Open Pro Rim
Results 1 to 2 of 2
    Feb 2005
    Have a CAAD 5 Cannondale on Mavic's Cosmic Expert, 16F/20R. Rim has a 27 mm. profile. I weigh 172 lbs. Will switching to a 28 or 32 hole open pro rim with dura-ace hubs have a big effect on ride comfort? Is it worth changing the wheel at all?
    Thanks,
    TheCapMan
    Feb 2002
    Change tire pressure
    Changing your tire pressure 5 psi (either way) will probably have more impact on comfort than making the wheel change you propose.
  1. Where can I find a 28 hole open pro rim?
    By IF Rider in forum Components, Wrenching
    Last Post: 11-30-2004, 01:57 PM
  2. Open Pro rim strip question
    By CoachRob in forum Components, Wrenching
    Last Post: 10-15-2004, 02:30 PM
  3. Open Pro Ultegra vs. Stock wheels...upgrade?
    By catfishnribs in forum Wheels and Tires
    Last Post: 07-14-2004, 05:08 PM
  4. Replies: 4
    Last Post: 06-18-2004, 12:34 PM
  5. DT RR 1.1 rims vs Mavic Open Pro
    By charlieboy in forum Components, Wrenching
    Last Post: 03-18-2004, 12:06 PM
