another will it fit 11 sp conversion question Zipp 404s
Results 1 to 6 of 6
    Aug 2009
    Hi,
    I have a set of 2013 Zipp Firecrest 404s. Im looking to upgrade to an 11sp. I have looked at all the specs and such, the hub differences but Im all confused.
    When I remove my cassette, the cassette mount on the hub is red and clearly states 10sp (expected). interestingly enough though there is a spacer between the back of the cassette holder and the cassette, it appears to be a little over a mm thick. I kept it in place and have enough clearance between the frame and the 11t cog.
    So is the case where I would just need an 11 sp cassette mount?
    ... and does it need to be the expensive zipp one?
    Thank you,
    Ron
    Is it a shimano cassette? Was there just one spacer? If yes to both that spacer came with the cassette and is always used on 99% of 10 speed hubs and basically has nothing to do with this situation. And the case would not be that you can just slap on an 11.
    Get in touch with Zipp. I think I remember hearing you can replace the free hub and get the wheel re-dished for 11.
    Aug 2009
    ah okay thank you.
    you're welcome.
    By the way I think this is what you need: https://www.jensonusa.com/Zipp-10-To...Conversion-Kit
    But not 100% positive so don't take my word for it. Talk to a decent shop, a wheelbuilder or Zipp to make sure. And I'm pretty sure you'll need a re-dish too.
    Aug 2009
    Yes it is a shimano drivetrain with a sram cassette
    Quote Originally Posted by rs_herhuth View Post
    hmmm.....you shouldn't have had a spacer on there is it was a SRAM 10 speed cassette on a 10 speed only hub.
    You say your wheels are 2013 and I think 11 speed came out in 2013.
    I'd say you were using the spacer required to run 10 speed on an 11 hub but there's this you said: "the hub is red and clearly states 10sp"
    So I really don't know now but I doubt Zipp printed 10 on there by mistake so can only guess someone put a spacer on by mistake.
  1. Shimano Freewheel - 9 sp 10 sp fit
    By marckap in forum Components, Wrenching
    Last Post: 03-02-2010, 05:56 PM
  2. 11 sp cranks on 10 sp???
    By customsteel in forum Campagnolo
    Last Post: 12-02-2009, 06:55 AM
  3. Record sp 10 & sp 11 compatability
    By fassa b in forum Campagnolo
    Last Post: 03-05-2009, 05:26 AM
  4. Conversion of 9 sp Record d/t shifters to 10 sp
    By DannyBoy in forum Retro-Classic
    Last Post: 06-12-2007, 08:16 PM
  5. 9 sp to 10 sp DA w/compact cranks conversion
    By cerveloguy in forum Components, Wrenching
    Last Post: 03-20-2007, 10:13 AM
