Barrel Adjuster or Cable adjusting bolt unit for Ultegra brake
Results 1 to 11 of 11
    May 2013
    So i was re doing the housing and cable on my bike and ran into an issue. The housing (even-though labeled 5mm) is actually 5.2mm without the ferrules So the cable housing wont slide into the barrel adjuster for a secure fit (Standard shimano barrels are for 5mm). I went to the bike shop and found that the cable (with or without ferrules) will fit into a 6mm barrel adjuster but they didnt have any that would fit the threads of my shimano ultegra 6700 brake. Any ideas of where i can get either a 6mm shimano barrel adjuster or some sort of adaptor??
    My issue: doesn't go into brake adjuster even without the ferrule
    I need this but 6mm
    Thanks for your help!
    la dolce vita
    Reputation: Mootsie's Avatar
    Have you checked to see if you are using brake housing and not shifter housing? The brake is a larger diameter. I mixed the two one time with results similar to what you are experiencing.
    insert witty comment here
    May 2013
    Yes i am very sure brake housing is thicker usually 5mm and shifter housing is usually 4mm. My issue is that my brake housing is 5.2mm and it is just slightly too big to slide that 1/2cm into the brake cable adjuster to allow a secure fit.
    Oct 2007
    You could check on the Jagwire POP ferrules. They are a step down design that fit perfectly into 6700 caliper adjusters. I am not sure what sizes they come in for the housing end though. They fit Jagwire housings perfectly.
    Feb 2002
    Quote Originally Posted by zeli0040 View Post
    Neatly trim the plastic off the cable housing where it will go into the barrel adjuster. And next time use stock casing.
    Not a rocket surgeon.
    Reputation: tihsepa's Avatar
    Nov 2008
    Ditch the cable housing end cap. Not needed on Shimano brakes.
    May 2013
    I just ordered some Hope they work thanks for the advise!
    Oct 2007
    You ordered what, POP ferrules? What type of brake housing are you using?
    May 2013
    I ordered Jagwire pop ferrules i have Yokozuna compressionless cables as i understood from reading about the POP ferrules they are for compressionless brake cables or for reinforced housing.
    May 2013
    The POP ferrules came! they worked perfectly! snugly fit on the compressionless cables and then narrowed down to also fit into the brake caliper barrels! Thanks davcruz!
    Oct 2007
    Glad they worked out for you, they really do fit the new Shimano brakes perfectly!
  1. barrel adjuster cable tension
    By shotojs78 in forum General Cycling Discussion
    Last Post: 02-25-2011, 02:20 PM
  2. Ritchey Cable Tension Barrel Adjuster for STI
    By toyota in forum Components, Wrenching
    Last Post: 10-20-2008, 09:06 AM
  3. Routing Front Brake Without Barrel Adjuster
    By lml1x in forum Cyclocross
    Last Post: 06-07-2007, 08:31 AM
  4. Brake Caliper Adjuster Barrel Won't Move
    By S2H in forum Components, Wrenching
    Last Post: 04-25-2006, 07:07 PM
  5. Headtube Cable Stops - What Kind of Barrel Adjuster?
    By JBF in forum Components, Wrenching
    Last Post: 05-25-2004, 11:12 AM
