Hello there ! Its my first post here. I have tried to understand some things about BB and compatibilities in general but i only get the simple things. I am going to upgrade my road bike with the new tiagra groupset and i have a simple question . Will the BB of the groupset fit the BB housing of my frame ? i have pictured my frame so you can tell me . Thanks a lot in advance !
Forgot to say that the groupset will include this : Shimano BB-RS500 BB Cups (Tiagra 4700)
Looks like you have a threaded bottom bracket, so yes the Shimano will fit. You will need to know if your BB is English or Italian (most likely the former).
Agree and would like to add: In order to distinguish BSA (=English) from ITA (=Italian), you may want to measure the width of your BB shell (excluding any BB cups) and have a closer look at the cups with respect to any (tiny) numbers/letters which might be engraved/printed on the outer diameter.
Further, I guess you are aware specific tools will be required to remove the existing BB and crank set and mount the new BB?
Hello again ! Appreciate all the info so far. I have ordered my Tiagra groupset with the bbrs500 cups. Just measured the housing width and its 6,7-6,8 cm that means 68mm. Im Italian or Bsa im confused . Reverend thanks for your concern. Yes im aware of some extra tools that are needed . (many vids on youtube help me assemble all the stuff needed )
Bikerjulio im thankful to you too mate. Im also glad i wont have to spend another 15-20 euros to an extra bb cup set cause i ordered before im 100% sure about my type of housing. So thank you all for your infos and ill be back with footage of the rebuild
The right tools are needed both to remove what you have ( I'm not sure from the photo) and to install the new cups. It may be worth finding a friendly bike shop to do it for you.
+1 to what bikerjulio says. While the outboard cups for the Shimano bottom brackets are easy to install it is always difficult to get the right tool for the Shimano version that you have. Sometimes there are running changes that require new tools. As an example, the spline tool for the Tiagra bottom bracket is not the same as that used for 105.
i find it ridiculous. Ok i understand the differences that should exist between the italian people ( Campy ) and the Shimano for example on the cassette freehub but dont understand differences between tiagra and 105 . Really should exist some universal type bolts ,tools etc at least among the earth priced groupsets. My search continues
Too late, but I would have recommended the Ultegra BB. Only a couple of dollars more, but twice as good as the Tiagra version. So based on what you ordered, you are going to need an Octalink or the appropriate tool to remove your square taper BB, then the tool specific to mounting the Tiagra cups and for the left-side crankarm preload.
Wish I could agree to that being completely true, but I can tell you that the tool that fit my Tiagra BB would not fit the new Ultegra BB that I replaced it with regardless of the adapter. YMMV but that was the fact for me. The adapter that came with my Ultegra BB served no purpose.
In fact there are some tools (non Shimano) which did fit the original design Shimano cups (e.g. current Tiagra) but are not compatible* with the adaptor that comes with the recent design Shimano cups.
However, if you purchase a Shimano TL-FC32 or TL-FC36 (or the "Pedro's" wrench in my picture), these will work with both cup designs.** (The TL-FC32 is certainly not a beauty but at some USD 10 an inexpensive tool for the non-frequent user.)
*) Note: That at first also was the case with my nice Chris King socket tool, but after some filing (of the adaptor, of course!) I managed to make it fit.
**) Original design as a direct fit, recent design by means of the adaptor.
Hello again mates after months of life big issues keeping me away from bike and free time .
I have updates on my issue. After months of recieving my order still havent fitted them on my bike . (big life issues ) . Meanwhile a real deal online made me buy a Felt (my first real road bike) which had Sora groupset. So i decided to swap Felt's Sora with the new Tiagra and move the Sora groupset to my noname alluminum bike. So i have a question.
From those things ive learned so far (and with your big help and infos) and as both cranksets are Hollowtech 2 i can simply remove the crankset from the Felt and put the Tiagra to the allreday installed cups right ? I also got some pics showing the only difference i see on the Felt's cups and the ones that came with my order. The cup of the bbrs500 read NG. From sope pics online i saw other letters too. Is it something like production code or somethings ? (but same dimensions numbers etc.)
Related Threads
Road Bike, Cycling Forums
5.4M posts
205K members
Since 1990
