bb size in 2009 sworks roubaix
Results 1 to 5 of 5
    May 2020
    I have a 2009 sworks roubaix and I want to change to a compact crank
    I cant seem to get and answer as to what OSBB means. am trying to narrow the filed on my buying options based on the BB needs. can anyone comment on this ?
    'brifter' is f'ing stupid
    Basically it's BB30 but 61mm wide rather than 68mm. Bearings are the same. What crank is on your bike now?
    #promechaniclife
    May 2020
    i know its oversize bottom bracket but is that BB30? or something else?
    May 2020
    thx cx its a FACT 53/39
    is there a diameter I can measure wit calipers
    Quote Originally Posted by pastnew View Post
    Yeah, just pull the crank out. It's either a 6mm allen or a T45. There's a Specialized tool for it that has the markings on it for whether or not it's screwed in all the way. It looks like a long black Torx bit in an adapter so you can put it on a ratchet drive. If yours is that old it's most likely the 6mm. If you have the SBC crank you can take off the rings/spider and get a compact spiker and rings and bolt them on to your arm.
    #promechaniclife
  1. New Sworks Roubaix!
    By brianb21 in forum Specialized
    Last Post: 03-06-2014, 10:41 AM
  2. 2009 Roubaix Comp vs. 2009 Roubaix S-Works SL2
    By jonehall in forum Specialized
    Last Post: 10-30-2009, 06:01 AM
  3. 2009 Roubaix Comp vs. 2009 Roubaix S-Works SL2
    By jonehall in forum Bikes, Frames and Forks
    Last Post: 10-27-2009, 07:17 PM
  4. sworks Roubaix SL Question
    By tmanley in forum Specialized
    Last Post: 03-26-2007, 04:23 PM
  5. My new Roubaix SWorks!
    By scico in forum Specialized
    Last Post: 04-18-2006, 11:14 AM
