BB30 cranck on Specialized Tarmac Sl3/SL4
Results 1 to 7 of 7
    Jul 2011
    Hello,
    I want to build up a Tarmac S-works frame. I need also a new groupset. I think I will buy Sram Force or Sram Red or a mix of both. I don't now if I need the BB30 version of the Sram crank. Can I use the BB30 crank in the tarmac frame or do I need adapters? Please some advice.
    Thanks.
    Reputation: QuattroCreep's Avatar
    Nov 2009
    Depends on the frame you get. The SL3 S-works comes in 2 BB types threaded and OSBB.
    From their website:
    S-Works Tarmac SL3 OSBB Frameset
    Spec your own ultimate road racing bike right down to the quick releases by starting with the S-Works Tarmac SL3 frameset. Oversized bottom bracket readily accepts BB30 cranks.
    Jul 2011
    Ok thanks...I assume that the SL4 frameset uses OSBB?
    Happily absent RBR Member
    Reputation: Kontact's Avatar
    Apr 2011
    Quote Originally Posted by Barts27 View Post
    Is this your frame?
    Specialized Bicycle Components : THE NEW TARMAC SL4
    Click on "technology".
    I wouldn't base component compatibility buying decisions on forum advice. Look at the frame's BB, ask the seller, get the serial number and call Specialized, etc. No one here is going to give you your money back if they get it wrong. No one here can guarantee they are speaking about the exact frameset you have or are getting.
    Reputation: Optimus's Avatar
    Jun 2010
    SL4 frame is only available w/ the OSBB I believe, but SL3 is available in both.
    "Those who like it, like it A LOT!"
    Jul 2011
    ok thanks.. I believe based on the information that a Sram REd or Force BB30 is possible on the OSBB. Thanks Kontact for the link!
    Jun 2010
    If you have the OSBB frame, then yes, you can get either Red or Force BB30 cranks.
  1. Specialized Crux & BB30
    By stunzeed in forum Specialized
    Last Post: 03-05-2014, 03:21 PM
  2. 2011 Tarmac S-works BB30 Bottom Bracket Question
    By Bike'em in forum Bikes, Frames and Forks
    Last Post: 09-08-2011, 11:30 AM
  3. Replies: 8
    Last Post: 03-01-2010, 05:13 PM
  4. Possible to convert Tarmac SL2 frameset to BB30?
    By rollin nolan in forum Specialized
    Last Post: 06-01-2009, 05:34 PM
  5. Replies: 5
    Last Post: 10-16-2007, 05:34 PM
