Is the BBInfinite that much better than the Shimano BB72-41B Bottom Bracket?
Results 1 to 14 of 14
    Sep 2015
    Hello,
    I see the demo of the BBInfinite BB spinning super freely, but in practical terms is it really that much better in actual riding than the standard ultegra Shimano BB72-41B Press Fit Road Bottom Bracket?
    I saw some info, that said the BBInfinite demo is a bit misleading, because under load the bearings perform differently and not that much better than the Shimano BB72-41B (?)
    I am doing a new build, and received the Shimano BB in the kit, wondering if I should drop $150 to $200 for the BBInfinite.
    Thanks,
    Ken
    'brifter' is f'ing stupid
    Long term it (BBI) will probably have less noise issues than a Shimano PF. I've installed a couple and I was reasonably impressed. Neither has had any problems at all. Get steel bearings not ceramic.
    #promechaniclife
    Sep 2015
    I am not so much concerned with long term reliability, but rather performance. Is the performance of the BBI that much better than the Shimano PF? In other words, will I spin that much more efficiently? less watts? The BBI cranks spins a lot more revolutions than the Shimano BB when on a stand and you give it a "twirl", but how much advantage is the BBI in real cycling under load?
    Quote Originally Posted by KiloKilo7 View Post
    Uhhhmmm...no. Does your living depend on this?
    The reason the crank 'spins' more on the stand is that the grease fill in expensive (espeically ceramic bearings) is less and thinner so they will do exactly what you're talking about. It gives the impression of a 'faster/more efficient' bearing.
    #promechaniclife
    xxl
    xxl is offline
    Moderator
    Reputation: xxl's Avatar
    Mar 2002
    I must take issue with this; ceramic bearings' efficacy is well documented, and can definitely benefit riders who spin at high cadences, say 50,000 RPMs or so.
    But that's not the only benefit ceramic bearings have; they are roughly three times as effective as SS bearings at getting money out of riders' wallets.
    Donald Trump has never had a wife he didn't cheat on.
    "Oh my god. This is terrible. This is the end of my presidency. Im fd.
    Quote Originally Posted by xxl View Post
    I can't believe I left these details out of my post, thankfully you were paying attention as usual and added the corrections. Whew.
    #promechaniclife
    Oct 2017
    I don't think any casual cyclist or mechanic is going to be able to quantify this for you. You might find someone on youtube (or somewhere) who has done some kind of test, but without some kind of complex scientific equipment there is no way anyone can tell you if, or how much better the performance is in one bottom bracket over another.
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    But just think of the bragging rights you will have with your riding buddies. You can make grunting noises while telling everybody you have superior ceramic bearings.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Ceramic bicycle bearings are a myth created to separate you from your money. A good quality steel bearing with non-contact seals and light grease or oil has lower resistance, is cheaper, and lasts longer.
    The only reason ceramic bearings 'feel' faster is because they use non contact seals and little to no grease. Moreover, ceramic bicycle bearings are NOT fully ceramic bearings. They are ceramic hybrids. The balls are ceramic and the races are steel. Which means the very hard balls will wear out the races faster... making them LESS efficient. Derp.
    www.hambini.com/ceramic-bearings-vs-steel-bearings-an-engineering-analysis/
    Ceramic bearings are red.
    Enduro is the Cermic beaing. OUCH! Your expensive ceramic bearing is less efficient after 1,000km
    Total Power saving
    The graph below shows how much power could be saved over 1000km between different bearing brands and their seal types. NTN, NSK and SKF dominate this chart and that is largely due to efficient seals and metal cages. The ceramic bearings which are coloured in red are not quite as efficient over a prolonged distance. If the evaluation window was extended to 10,000km, the ceramic bearings would perform much worse as a more significant track would have worn into the bearing races thereby increasing friction.
    But hey... if you're racing for money, have the budget, and a race team to continually maintain your bearings every 1,000km, by all means go ceramic. But of course, you could do it cheaper (with less resistance) by just taking the grease out of your steel bearings.
    Feb 2002
    You're underestimating the value of ceramic bearings. Their benefits tend to kick in at more like 5,000 RPM. Plus they are a lot better in highly acidic environments. So jet engines, steam turbines, chlorine compressors. Stuff like that. Stop trying to minimize their benefits!
    Feb 2002
    More to the point, if you are racing for money AND your sponsor makes ceramic bearing products or you can get a sponsor who makes ceramic bearing products, by all means . . . .
    xxl
    xxl is offline
    Moderator
    Mar 2002
    Obviously you don't know how to really spin, and 50,000 RPMs is above 5,000 RPMs, so there.
    As to highly acidic environments, I haven't ridden like that since the Seventies.
    Banned Sock Puppet
    May 2014
    If you can remember the 1960's, you weren't there.
    "With
    -- DCGriz, RBR.
    Quote Originally Posted by Finx View Post
    So in saying no one can answer you've actually answered, correctly, the question too.
    The question was: "is it really that much better in actual riding" Not: Is there some minute difference that MIT might be able to detect.
    If no one this side of Nobel prize winners can figure it out then it's not going to make a difference in my riding.
  1. BB72 tear down
    By ongbenghui in forum Components, Wrenching
    Last Post: 03-24-2018, 09:01 AM
  2. Special Thanks to Wes @BBInfinite!
    By AtTheDrop in forum General Cycling Discussion
    Last Post: 11-25-2015, 05:14 PM
  3. Replies: 8
    Last Post: 08-25-2007, 09:19 PM
  4. A better bottom bracket?
    By Wisbiker in forum Components, Wrenching
    Last Post: 04-06-2005, 06:42 AM
  5. Carbon or Ti, are they that much better than Al
    By dogmanmsu in forum Bikes, Frames and Forks
    Last Post: 08-21-2004, 02:05 PM
