Berk Dila 140mm Review
Results 1 to 1 of 1
    Aug 2013
    I wasn't able to find many in depth reviews on the Berk Dila so I took a bit of a gamble purchasing it and also having the bridge custom painted to match my bike. I heard many good things about Eric from www.elitevelosolutions.com so I tried my luck with him. He was always prompt in answering questions and kept me up to date with the status of the saddle. There was a little delay in receiving it not on Eric's part, but it wasn't too bad. I had contacted Eric long time ago when the Dila 160 came out and Eric felt it would be too wide for me so I dropped that idea. When I heard about the 140mm I made the purchase. For whatever it's worth I'm 148 lbs and my sitbone width is 109 mm apart. I'm 5'7 and on a size 52 cm frame. This is the round rail version. I can't really tell if this saddle dampens vibration more than the PRO Stealth as I didn't really pay attention to that and is hard to compare.
    My saddle came in at a nice 105 grams
    I had Berk paint match the bridge to the bronze accents on my Wilier Zero.6
    A few photos on the bike
    Now onto my thoughts of the saddle. I will be comparing it to the Shimano PRO Stealth saddle a lot since that's my favorite saddle before the Berk. It was hard to find a straight side shot of the saddle before I purchased it so let's start with that.
    I tried to angle the saddles in the photos as close to how I have them leveled on the bike. On the Pro Stealth I had the nose slightly higher, but the area you actually sit on pretty much level. This created a very nice stable cradle for the hips. Even though both saddles have a scoop at the rear, you definitely feel it more on the Pro Stealth which I personally liked. I'm curious why saddle makers don't make the actual part your sit bones are on level with the ground instead of sloping down which I would think makes you slide forward. Anwyays it isn't really an issue. You sit much further back on the Berk Dila than the Pro Stealth due to where the flare on the sides starts. This creates an issue for me because with the Pro Stealth and a -15 mm offset seatpost, the seatpost clamp winds up pretty much in the middle of the rails, where as on the Berk Dila I have to push the saddle all the way forward. I guess that's an excuse to buy a 0 offset seatpost.
    You can see in this picture. The redline is about where my sitbones would be and you can see how far back on the rails it lines up with
    Where as on the Pro Stealth to get the same position the clamp winds up here.
    The nose on the Pro Stealth is usable even though they are about the same size where the Dila is not really. I think it's because of the flatter side to side profile of the entire saddle and also the nose does sit about an inch shorter than the Dila based on where you actually sit. Also the PRO Stealth shell is much more rigid including the nose to be able to support your weight on it versus the Dila that's kind of a hammock. There is just no way around getting really low / forearms on the handlebar / flat back without being able to clear your nuts over the nose. The Dila nose is too long specially considering the distance between where you sit normally and the tip. It also doesn't feel wide enough. I'm not sure why it is billed as a road/tri/tt saddle. You can still get in the drops fine, but more difficult to get flat back.
    Below is the two saddles overlaid on top of each other.
    The photo below is lining up where I would actually sit on the saddles.
    I've only had two rides on the saddle so far so these are preliminary impressions. First ride was 20 miles to figure out the fore / aft and saddle tilt. Second ride was a climbing ride up Glendora Mountain Road 37 miles with 3500 ft elevation. My biggest gripe about the saddle is I wish it was flatter side to side when looking at it from the back.. like the Pro Stealth. So it does effectively reduce the saddle width and you do feel a little more pressure up the middle. Although I did notice it when first trying it out, it's not really an issue. It's never enough pressure that it's a nuissance and you don't think about it. I would prefer a slightly larger center cut out also. The ride had long seated climbing at about 5-6% and I never got any numbness to the penis. I did have that happen on a few rare occasions with the Pro Stealth even, but I think all saddles can cause this and can be avoided by just shifting around and standing from time to time. By the end of the ride I didn't have any soreness anywhere. The flex in the saddle really works like others have said and it's quite amazing since the padding is so minimal. Sit bone/ pubic rami pressure was well controlled and I couldn't really tell a difference between padding amount between the two saddles. Sometimes with the Pro Stealth it would get a little sore right where the sitbones are pressing into the saddle. That being said, I think professional riders will prefer the PRO Stealth because you do feel like you are more solidly planted on the bike if that makes any sense.
    I should have taken a photo of the rear profile, but hopefully user refthimos doesn't mind me using his. This is demonstrating how much flatter the Pro Stealth is.
    Here are some photos of the caliper set at 110 cm which is my sitbone width. Obviously we don't sit straight up on the saddle.
    Here you can see how much more of the saddle will go up the middle with the calipers still at 110 (of course our sitbones aren't the shape of a caliper) and resting on the saddle.
    In conclusion I'm happy with this saddle and will report back after doing longer rides such as 100 miles and see how my bottom feels then. Even though I have a few small issues with the saddle (saddle rail positioning, not being flat enough, nose not as usable as PRO Stealth), by the end of the ride nothing was sore so that's a huge plus. If I had to choose another saddle for a weight weenie bike then the Dila would be an easy pick. If I had to pick another for an aero bike I probably would get the PRO Stealth again specially since I have one lying around. One last thought is I appreciate how the Dila wraps the edges down so you dont feel a hard edge against your thighs.
  1. Rear Post Adapter for 140mm to 160mm - Shimano R785
    By allenpg in forum Components, Wrenching
    Last Post: 02-08-2016, 09:35 AM
  2. Anyone run 140mm disc rotors up front?
    By Shogunade in forum Components, Wrenching
    Last Post: 10-07-2014, 04:48 PM
  3. Hakkalugi disc, anyone set up a 140mm rear yet?
    By rensho in forum Cyclocross
    Last Post: 12-14-2012, 10:46 PM
  4. Long Stems - 140mm+
    By tmanley in forum Components, Wrenching
    Last Post: 05-24-2006, 04:21 PM
  5. who stocks OS 140mm stems?
    By naawillis in forum Components, Wrenching
    Last Post: 05-08-2005, 04:28 PM
