Best tire pressure?
Results 1 to 3 of 3
    Jul 2008
    Best tire pressure?
    My tires has a 120psi max. What pressures should I run to still have good grip while cornering? 110, 100, 120? thanks
    Steaming piles of opinion
    Reputation: danl1's Avatar
    Quote Originally Posted by RyanM
    There are two other threads on the page discussing this exact topic.
    http://forums.roadbikereview.com/sho...d.php?t=173949
    http://forums.roadbikereview.com/sho...d.php?t=174714
    A: Less than 120, in all likelihood. Cornering would be aided by lesser pressure, in any case, but the final answer will depend on your weight, tires you are running, and your road surface conditions.
    A good habit is as hard to break as a bad one..
    n00bsauce
    Reputation: Mel Erickson's Avatar
    The lowest pressure you can get away with without getting pinch flats.
    "Those who can make you believe absurdities can make you commit atrocities." Voltaire
    There are your fog people & your sun people, he said. I said I wasn't sure which kind I was. He nodded. Fog'll do that to you, he said.
    "We are all ignorant about most things."
    Mel Erickson
