Black Campy Chainrings
Results 1 to 8 of 8
    Jan 2008
    Hi All
    I am looking for good quality chainrings to suit current Campy cranksets which are either entirely matt black or dark grey. I particularly want to avoid chainrings with silver / shiny machined teeth or over the top grahics. Any suggested sources / products would be very welcome.
    Also interested to know if there are any views on performance of aftermarket chainrings in comparison with original items?
    Many thanks
    Oct 2002
    TA and Stronglight
    Both these companies make chain rings that will fit Campy in the color schemes you want.
    Reputation: ti-triodes's Avatar
    Aug 2006
    After a few rides they're going to start turning silver anyway.
    Jan 2005
    Campy Crank & other rings not compatible
    Be careful. I just discovered that my Campy Ultra Torque Crank has some strange bolt pattern. The BCD is suppose to be 110mm on my compact crank. I'm running a 50/34 and an 11x21 or 23. I decided I wanted to add a little more high end speed by switching to a 52/36.
    Both of the new chainrings I wanted to add are FSA 110 BCD. However, the bolt attachment behind the crankarm doesn't line up. When I lay the Campy rings on the FSA rings I noticed that the Campy rings have one bolt hole which is offset from the others. Very weird.
    So I guess I'm limited to Campy rings only.
    Or does anyone know where to get a compatible set or 52/36 rings?
    Oct 2002
    Not really
    TA now makes rings to fit the Campy compact crank. It's called Nerius.
    Jan 2005
    Thanks
    Wish I knew that b4 I got the FSA rings.
    I just figured 110BCD = 110BCD.
    Fast No More.
    Reputation: Slow Eddie's Avatar
    Jun 2004
    Quote Originally Posted by aizu1
    Unfortunately, not with UT compact. It's 110 + 112: 112 mm for the hole that lines up with the crankarm.
    Also, a caveat with aftermarket rings. There have been some threads about some rings that are said to fit UT compact, but it turned out not to be the case. Not sure if TA rings were mentioned, but it would be worth double-checking before buying.
    EDIT: Here is the thread. Looks like TA rings were the culprit.
    Work to Eat | Eat to Live | Live to Ride | Ride to Work
    Knives, Guns, and Booze
    Reputation: Leopold Porkstacker's Avatar
    TA Specialities. Fairwheel Bikes is where I purchased mine from.
