Bottle cage bolts stripped
Results 1 to 12 of 12
    Mar 2012
    Bottle cage bolts rounded stripped head
    Bottle cage bolts rounded very easily off a new bike. Now can't get them off. Seems like a very soft material for the bolts and they rounded so easily.
    Mar 2012
    Using a Dremel to put a line in the bolt to be able to use a flat head seems like a good option. Should I give thay a go?
    Jul 2008
    Same thing just happened to about 2 weeks ago! It was my first carbon bike and I thought I messed it up something fierce. My shop said it happens sometimes. They had to drill it out and replace the rivnut. It was the manufacturers fault they said. All good now, but they had it for a few days.
    'brifter' is a lame word.
    I'm not sure what you need more help with...grammar or getting these screws out. Please at least try to make your posts easy to read.
    I work for some bike racers
    and a bunch of skateboards
    Mar 2012
    Shop had to use a Dremel. Worked good. They couldn't believe how soft the screws were.
    Neophyte
    Reputation: jetdog9's Avatar
    Jul 2007
    Bolts can be soft and people can seriously over-tighten. Make sure tool is properly engaged and DEFINITELY invest in a torque wrench. They aren't as expensive as they used to be.
    Banned forever.....or not
    Aug 2002
    What size allen wrench did you use? Were the bolts aluminum or Ti??
    Dogbert.
    I>U
    Seems like many brands are using aluminum bottle cage bolts. I generally always replace them w/ SS. It's easy to strip them, and over time to break them after yanking bottles out of the cages for a few months. Seems like I'm drilling broken ones out every week or so.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Yes use stainless steel and apply a small dab of grease on the threads. Makes it much easier to remove down the road.
    Sent from my SM-G977U using Tapatalk
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Feb 2002
    Quote Originally Posted by frdfandc View Post
    And if you continue to use Al bolts, be SURE to grease the threads. Aluminum screws can easily gall the threads and then you're in deep greases.
    What the what???
    Jul 2009
    Good god, man, how much of a gorilla are you?
    Given his penchant for nicknames, and his aversion to reading, I've decided to shorten Donald J. Trump to it's essence: Dump*
    Quote Originally Posted by Opus51569 View Post
    Not me, I'm old and weak!
  1. Stripped bottle cage thread
    By SlowJoeCrow in forum Bikes, Frames and Forks
    Last Post: 11-12-2011, 08:23 PM
  2. anodized bolts/Ti bolts... bolts in general...
    By Cruzer2424 in forum Components, Wrenching
    Last Post: 02-16-2007, 06:56 AM
  3. Bottle Cage thread stripped
    By West End Rail, NJ in forum Components, Wrenching
    Last Post: 02-25-2006, 08:39 AM
  4. What bottle cage bolts?
    By BugMan in forum Components, Wrenching
    Last Post: 10-02-2004, 05:38 PM
  5. Water Bottle Cage Bolts--what size are they?
    By mk_42 in forum Components, Wrenching
    Last Post: 06-09-2004, 11:59 AM
