Bottom Bracket Cable Guide Question - Specialized Roubaix
Results 1 to 3 of 3
    Apr 2004
    Frame is a 2005 Specialized Roubaix Elite carbon. The bottom bracket guide is so low profile (thin, snug against the frame) that the cables rub on the downtube/BB shell before they enter the plastic guide. Seems like I need a higher profile (thicker) guide, but this also has a "tail" that goes up through a hole in the frame to keep the FD cable from rubbing the the routing hole in the carbon frame, so a generic won't do it. Anyone else had a similar problem? Any solutions? Seems like a design flaw by Specialized.
    solution...
    I've got this problem to as very minor extent on one frame. Some thin plastic shim material should cure the problem. Perhaps part of a old clear plastic water bottle of any flexible plastic container, cut to the size of the cable guide.
    n00bsauce
    Reputation: Mel Erickson's Avatar
    Strip out a piece of plastic inner housing from a section of cable housing and thread it onto the cable where it rubs on the BB shell.
    "Those who can make you believe absurdities can make you commit atrocities." Voltaire
    There are your fog people & your sun people, he said. I said I wasn't sure which kind I was. He nodded. Fog'll do that to you, he said.
    "We are all ignorant about most things."
    Mel Erickson
