Bottom Bracket Q
Results 1 to 3 of 3
    Reputation: PBL450's Avatar
    Apr 2014
    Bottom Bracket Q
    I’m looking at a frame with a BSA threaded BB, the size is not listed... I’d like to build the frame with SRAM Red mechanical rim. From what I can see from google that shouldn’t be a problem but I wanted to double check here with far more knowledgeable people than Google Wrench. Any feedback is appreciated.
    To date, philosophers have merely interpreted the world in various ways. The point however is to change it.
    'brifter' is f'ing stupid
    It doesn't matter. BSA bottom brackets are +/- 68.0mm. Just get a BSA SRAM GXP bottom bracket and crank and you're done.
    #promechaniclife
    Apr 2014
    Thanks CX, much appreciated!
  1. Advice Installing Campy Bottom Bracket
    By Gibralter00 in forum Campagnolo
    Last Post: 05-11-2005, 05:35 AM
  2. Bottom Bracket info Giant TCR Composite?
    By wasfast in forum Components, Wrenching
    Last Post: 02-11-2004, 10:03 PM
  3. Bottom bracket - most important features
    By cossington in forum Components, Wrenching
    Last Post: 02-11-2004, 01:07 PM
  4. Advice Installing Campy Bottom Bracket
    By Gibralter00 in forum Components, Wrenching
    Last Post: 02-10-2004, 08:53 AM
  5. Bottom bracket or rear hub problem?
    By reddpoint in forum General Cycling Discussion
    Last Post: 02-05-2004, 07:52 PM
