Bottom bracket question
Results 1 to 4 of 4
    Apr 2016
    I have a Specialized Tricross (https://www.specialized.com/us/en/tr...t-disc/p/49858). Over the winter I'm changing it over to a SRAM 1x drivetrain. I'm not sure what I need to look for in terms of a bottom bracket. It says "Shimano, outboard cartridge bearings, 68mm shell" but is that enough to go on to be able to tell what to replace it with? If not what to I need to do to make sure I get the right size?
    'brifter' is f'ing stupid
    That is enough info. Your frame has a 68mm threaded bottom bracket shell. SRAM offer 2 cranks that will work with their corresponding bottom brackets. GXP is the 'old' style crank with a stepped axle (24>22mm), and the 'newer' DUB design that uses a 29mm axle. I'd recommend DUB as that's what SRAM are moving towards. Just make sure you get a both a DUB crank and bottom bracket, and that the bb is BSA(English) threaded.
    #promechaniclife
    Oct 2013
    CXW makes it sound really simple!
    BANNED
    Apr 2016
    Awesome. Thanks!
  1. Bottom Bracket Size Question?
    By herzeleid in forum Components, Wrenching
    Last Post: 03-24-2005, 01:27 PM
  2. Replies: 2
    Last Post: 12-16-2004, 09:13 PM
  3. Bottom Bracket width/sizing question
    By astroclimb in forum Components, Wrenching
    Last Post: 12-02-2004, 01:06 PM
  4. Crankset and Bottom Bracket Question
    By khill in forum Cyclocross
    Last Post: 08-02-2004, 03:51 PM
  5. Bottom Bracket Question
    By Dorf411 in forum Components, Wrenching
    Last Post: 03-15-2004, 02:03 PM
