Which Bottom Bracket for Vintage Frame?
Results 1 to 5 of 5
    Sep 2018
    So...latest project is a vintage steel frame that I want to upgrade to SRAM Force or perhaps a lower-grade offering (Rival?) The frame is a late 80s vintage Specialized road frame. I assume that neither GXP or BB30 will fit. Correct? What are my choices when installing the newer groups? Does SRAM make a BB that will fit a vintage frame and work with the new parts, or will the parts work with the original bottom brackets that came with these vintage frames?
    Thanks in advance...
    Feb 2002
    Quote Originally Posted by mml373 View Post
    BB has to match the cranks and the frame, so you need a BB that is standard English thread and is compatible with whatever cranks you want. The original BB that came with that frame might have been square taper (ISO or JIS) or perhaps Shimano Octalink. Not sure about the latter as to what proprietary BB Shimano was pushing in that time frame.
    'brifter' is f'ing stupid
    Why wouldn't GXP work? That's what it was designed to work in. You need English GXP cups and whatever SRAM GXP crank you want to use.
    #promechaniclife
    Sep 2018
    Thank you both. Current BB is a Specialized square taper, vintage 1987. I'll take a closer look at the GXP BBs... Thanks again.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    Remove the square taper and install the GXP. It will fit fine. The 30mm spindle will not fit.
    I've done some upgrades to older bikes in the past, like a full Ultegra kit, crank included, in an old Schwinn Paramount for a customer.
    Sent from my SM-G930V using Tapatalk
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
  1. help with bottom bracket: vintage mundo caloi racer
    By AttackMonkey in forum Components, Wrenching
    Last Post: 02-26-2014, 04:53 AM
  2. Vintage Zeus Bottom Bracket
    By gmvgmvgmv in forum General Cycling Discussion
    Last Post: 02-20-2013, 03:36 PM
  3. Vintage Zeus Bottom Bracket Spindle
    Last Post: 02-10-2013, 06:09 PM
  4. vintage bottom bracket/crank incompatibility?
    By fmradio516 in forum Campagnolo
    Last Post: 09-17-2009, 05:24 AM
  5. Vintage Chorus Bottom Bracket
    By JaeP in forum Campagnolo
    Last Post: 08-05-2005, 06:27 AM
