bottom bracket washers
Results 1 to 3 of 3
    Oct 2004
    Question bottom bracket washers
    Hi,
    My bike has 2 ~ 1 mm thick washers installed between the drive side bottom bracket cup and the frame's bottom bracket shell.
    It is like that originally and the drivetrain works fine.
    Has anyone the same kind of assembly ?
    I'm interested to know :
    a. what's the reason for not threading the drive side bottom bracket cup directly into the
    botton bracket shell ?
    b. could it cause any damage to the frame's bottom bracket shell ?
    Your opinions & experince will be much appreciated.
    Thank's
    Jun 2004
    they're spacers.
    Sometimes ther're needed for the purpose of getting a proper chainline.
    If you have short chainstays a 1-2mm spacer can get rid of chain rub in the small/small ring combination. Not that you should be riding in that gear anyway.
    rayms
    Sep 2013
  1. American Classic Split rinb ISIS bottom bracket.
    By Juanmoretime in forum Components, Wrenching
    Last Post: 06-18-2005, 02:44 AM
  2. creek in the bottom bracket
    By saccycling in forum Components, Wrenching
    Last Post: 11-15-2004, 10:32 AM
  3. Help with stuck bottom bracket
    By mfuchs in forum General Cycling Discussion
    Last Post: 05-19-2004, 04:30 PM
  4. Creaky bottom bracket? Loctite? Plumbers tape?
    By mtbcyclist in forum Components, Wrenching
    Last Post: 04-21-2004, 05:22 AM
  5. Fitting FSA ti bottom bracket - problems?
    By Gilo in forum Components, Wrenching
    Last Post: 04-06-2004, 07:26 PM
